Engine issues when its Cold outside
Discussion in '4 Cylinder' started by sshirley, Nov 12, 2014.
  1. Nov 12, 2014 at 8:34 AM
    sshirley
    sshirley [OP] Well-Known Member
    Sam
    Austin
    2000 Tacoma SR5 with 400k miles
    Stuff
    Hi All,
    I have a 99 4x4 with the 3rz and 403,000 miles.
    Yoda doesnt really like winter.. Last year the front main seal cracked and the valve covergasket started leaking. Front main seal was replaced. The valve cover gasket leak is really small and not a huge concern. One of these days I will get around to it.
    This morning it was about 45 degrees out, and it ran really rough for about 15 minutes, shook a bit, rough idle. Sounded just like a loud power steering pump, except that I do not have power steering. And the noise did not change with RPM, it was a consistent noise.
    Anyone else have issues when cold out?
    Any thoughts would be helpful.
    Thanks,
  2. Nov 12, 2014 at 11:01 AM
    Indy
    Indy Master of all I survey.
    You're in texas. If 45 is cold and your truck has issues, it would probably not run right up here in the middle of summer. 45 is tshirt weather. We were -10 + windchill last night probably pushed it to -30. Mine cranked slow for a couple extra seconds before firing, pretty normal for the temps.
    With 400k on the odo, I'd say that is the actual problem. There's not much you can do short of a new(er) engine.
  3. Nov 12, 2014 at 11:03 AM
    sshirley
    Sam
    Austin
    Stuff
    It was actually closer to 40.. yes I know that isnt "cold" but if the truck is used to 100 plus degress all the time 40 is a bit of a difference.
  4. Nov 19, 2014 at 1:26 PM
    Speedytech7
    3435 E Trent Ave, Spokane, WA 99202
    It's less Tacoma and more mod
    Hmm, mine makes some more noises in the -10 to 18 degree weather. Generally the PS pump is pissed about thicker hydro fluid. My 3RZ is usually just super high idling in the cold, but it becomes normal very quickly. Maybe your distributor and plugs need service if they are becoming more effective when it is hot out. Could just be getting low o compression though, no real cure for that besides a rebuild.
  5. Nov 19, 2014 at 8:47 PM
    Yota Bird
    Yota Bird Active Member
    Johnathan
    North Carolina
    99 White Prerunner 2.7L
    6K HIDs,6K LED Foglights,Magna Flow Hi-Flo Cat,Flowmaster 40,Tinted Brake Lights,Clear Corner and Turn Light Housings
    My has issues during the cold also, it was around 17 this morning..I have like a loud grinding noise coming from mine, sounds like the fan getting stuck or something but it only happens with it get below like 35 degress outside..any idea what that is ?
