Engine keeps revving after declutching
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jimmydolittle, Aug 7, 2017.
  1. Aug 7, 2017 at 8:03 AM
    jimmydolittle
    jimmydolittle [OP] Member
    09 Taco
    My 09 taco 4.0L 6 speed manual, wants to keep revving when the clutch is depressed, and let off the gas for several seconds. Is that a common characteristic with these? Also, it doesn't drop below 1100 rpm when hyper mileing unless the AC is on, then it drops to 1000.
    I grind 3rd gear whether I'm shifting up, or down, double clutching might help, don't know haven't tried yet.
  2. Aug 7, 2017 at 8:11 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Your high idle can cause issues like your explaining. Should be around 600.
    jimmydolittle[OP] likes this.
  3. Aug 7, 2017 at 8:19 AM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    the shifting in my 07 manual is completely smooth going up or down through every gear. When jamming hard I might miss third now and then but no grinding whatsoever.
  4. Aug 7, 2017 at 9:40 AM
    jimmydolittle
    09 Taco
    It will drop to 850 when at a stop light.
  5. Aug 7, 2017 at 8:26 PM
    Hawforne
    Hawforne Well-Known Hater
    O-Diggity
    West KY
    12TRD
    Tons of gay shit
    Tacoma ECU keeps the idle up while moving to "aid in better shifts". Maybe ask around and find out if that's part of the program for your year. Mine does and it is a 2012.
  6. Aug 7, 2017 at 9:00 PM
    81shark
    81shark Well-Known Member
    leave it in 5th... errr. 6th.
    Hawforne likes this.
  7. Aug 8, 2017 at 4:01 AM
    jimmydolittle
    09 Taco
    I usually shift 1,2,4,6. I have a 4 speed.
  8. Aug 8, 2017 at 6:35 AM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    It's called "rev hang", it's normal, but yours seems a bit high. First thing to do is clean the throttle body, MAF sensor and make sure you have no vacuum leaks.
    Lot's of info on both procedures here.
  9. Aug 8, 2017 at 6:58 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Bleed clutch. Rev hang is normal. Want to get rid of it, get the OVTune when available (if they stop the rev hang), or an aftermarket Stand-alone.
    12TRDTacoma likes this.
  10. Aug 8, 2017 at 8:57 AM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    Yep they all do that (rev hang).
    I don't notice it much in the 6MT. My 4-cyl 5 speed would actually rev UP shifting from 4th-5th gear.
  11. Aug 8, 2017 at 9:53 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Factory Performance rev match. :D
