Engine kill switch
Discussion in '1st Gen. Tacomas (1995-2004)' started by blitzburgh99, Apr 4, 2012.
  1. Apr 4, 2012 at 9:28 PM
    blitzburgh99
    blitzburgh99 [OP] Well-Known Member
    Houston, TX
    1999 Tacoma TRD 4x4
    239,600 (as of 7-20-13 and counting)original owner miles
    I am looking to increase security of my 1999 trd taco. It has the factory alarm, and I would like to add an engine/ignition kill switch. Can anyone recommend one that is an easy do-it-yourself install?
  2. Apr 4, 2012 at 9:31 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    A wire with toggle switch to the coil. What i used for a vw bug.
  3. Apr 4, 2012 at 9:41 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    You could wire a switch into the relay harness at the ignition switch, part you put the key in, or just pull the fuel pump fuse which is what I do if I leave my truck in a parking garage or on the street. I also pull it every night before going to sleep.
