Engine knock?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WOODEX M.E., Nov 12, 2016.
  1. Nov 12, 2016 at 7:36 AM
    WOODEX M.E.
    WOODEX M.E. [OP] Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Hey guys looking for an opinion. I started my truck this morning and immediately made a knocking noise I have never heard. I restarted it and it continued for a min or so and then died off quickly to a light tick and then a few min later it went away completely. Now it purrs like a kitten. Checked and I have proper oil level although it looks kinda black. I am thinking stuck lifter? I have a supercharger and no catch can. Wondering if this is a result of 80k miles without one. Sorry for lack of info, on my phone.
  2. Nov 12, 2016 at 7:40 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    It won't be a stuck lifter, since these engines use a solid bucket style lifters, not hydraulic lifters that can collapse / stick.
  3. Nov 12, 2016 at 7:47 AM
    WOODEX M.E.
    Corey
    Maine
    At first I thought it was a connecting rod or something, but that would not go away. I'm not familiar enough with the insides of these engines.
  4. Nov 12, 2016 at 7:48 AM
    WOODEX M.E.
    Corey
    Maine
    Also this was a cold start this morning. Ambient temp about 38F.
  5. Nov 12, 2016 at 8:00 AM
    Pro Taco 11
    Pro Taco 11 Sitt Head
    Rob
    Joliet, Illinois
    Tacoma TX Pro 2011 4x4
    3" OME, RAAL, TRD Exhaust, Pioneer DBL DIN, Weather Tech's, Bull Bar, AFE CAI, Anytime Fog, Map/Dome light mod, Ultra Gauge, Tail Gate theft mod, Second Set of D-Rings in bed, Dura Tracs 285's, Satoshi deep dish, Leer 100 XQ, Wet Okole seat covers
    I get that too but not as severe. Start up once in a while, lil knocking noise for 10 seconds and goes away. Was thinking lifters myself
  6. Nov 12, 2016 at 8:06 AM
    WOODEX M.E.
    Corey
    Maine
    This is the first time it has done it. And the fact it went away makes me think something was stuck somewhere.
  7. Nov 12, 2016 at 8:23 AM
    Pro Taco 11
    Rob
    Joliet, Illinois
    Its done it a cpl times to me. Changed oil and no difference. Temp outside below 40 degrees. I saw in manual at the 60,000 mile service to check tightness on lifters but if lifters were loose it would do it all the time right?
  8. Nov 12, 2016 at 8:24 AM
    Pro Taco 11
    Rob
    Joliet, Illinois
    I also thought that the starter stuck at first, it was around the same time I changed my dead battery.
  9. Nov 12, 2016 at 8:26 AM
    Pro Taco 11
    Rob
    Joliet, Illinois
    I am not s/c but did put on an oil catch can 800 miles ago. Through 2 oil samples found gas in my oil. Dint know if catch can will help this or not but I'll give it a try.
  10. Nov 12, 2016 at 3:49 PM
    WOODEX M.E.
    Corey
    Maine
    Hmmmmm. I will check about the adjustment on the lifters.
  11. Nov 12, 2016 at 4:09 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Like said above lifters are a shim and bucket type. If you had lifter noise it should be a consistent ticking noise. Not something that would disappear. Adjustment would be made by measuring and replacing shims to correct thickness.
  12. Nov 12, 2016 at 4:28 PM
    jersey jim
    jersey jim Well-Known Member
    Jim
    2018 Cement DCSB TRD Sport 4x4 6MT
    My '15 V6 had a bad rod bearing at 10k miles, sounded fine at startup, once it got warm and oil thinned up it made a nasty noise. Ended up with a new short block.
    I'd lean more toward valve train for a startup noise, but go get yourself a mechanics stethoscope and see if you can tell where it's coming from before thinking about taking anything apart.
  13. Nov 12, 2016 at 5:14 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    piston slap
    1R0NMAN811 likes this.
  14. Nov 12, 2016 at 6:20 PM
    WOODEX M.E.
    Corey
    Maine
    This doesnt sound like any piston slap i have ever heard.
  15. Nov 12, 2016 at 6:24 PM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    Sounds like a timing chain tensioner.
  16. Nov 12, 2016 at 6:27 PM
    jbrnigan
    Midwest
    yeah......me neither
  17. Nov 12, 2016 at 6:33 PM
    WOODEX M.E.
    Corey
    Maine
    Guess i will see tomorrow morning. I let it sit for 3 -1/2 hours today in 40deg weather and it was fine at startup. Hopefully tomorrow if it repeats itself i have something to go on.
    Ill take a video this time.
  18. Nov 12, 2016 at 6:35 PM
    NM Lance
    NM Lance Well-Known Member
    Let me guess, you have the 4.0 V6?
  19. Nov 12, 2016 at 9:36 PM
    WOODEX M.E.
    Corey
    Maine
    That is correct.
  20. Nov 13, 2016 at 12:23 PM
    WOODEX M.E.
    Corey
    Maine
    Cold start up today.....everything was fine.
