Engine Knock
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacocam04, Mar 1, 2023.
  1. Mar 1, 2023 at 11:54 AM
    tacocam04
    tacocam04 [OP] New Member
    2021 Tacoma SR5
  2. Mar 1, 2023 at 11:55 AM
    LilTexan22
    LilTexan22 Well-Known Member
    2017 Tacoma
    Sounds normal
    Junkhead, kahanabob and cropduster78 like this.
  3. Mar 1, 2023 at 12:05 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Sounds like a perfectly fine and healthy 2GRFKS.
    Enjoy your truck!
    usmc2msu, kahanabob and eurowner like this.
  4. Mar 1, 2023 at 12:07 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Engine knock who?
    BSFord, Servingko and Junkhead like this.
  5. Mar 1, 2023 at 12:51 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Blak Shinobi likes this.
  6. Mar 1, 2023 at 1:12 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    See if you can isolate the sound as per the TSB: https://static.nhtsa.gov/odi/tsbs/2022/MC-10230385-9999.pdf
    According to the TSB, the vacuum pump is covered by the bumper-to-bumper warranty, not the powertrain warranty. If the vacuum pump is indeed making excessive noise, you have ~1k miles before the warranty runs out.
  7. Mar 1, 2023 at 2:40 PM
    clownkillerloaf
    clownkillerloaf Well-Known Member
    Logan
    2025 SR 4X4 DCSB
    A little vac pump clatter. If you're losing sleep over it, there's a tsb for a replacement that *may* not clatter as much. Mine sounds just like yours, sounded the same when I bought it 50k miles ago at 23k miles. Keep us posted, op.
  8. Mar 1, 2023 at 5:51 PM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    burnttaco7 and Junkhead like this.
  9. Mar 1, 2023 at 5:52 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Junkhead likes this.
  10. Mar 1, 2023 at 5:53 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Exactly.
    BLtheP[QUOTED] likes this.
  11. Mar 1, 2023 at 5:54 PM
    Blak Shinobi
    taco
    n/a
    seems normal but if your uneasy take it to toyota . what I do check for once in awhile is if my timing is leaking , everytime i check its bone dry
  12. Mar 2, 2023 at 5:05 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Sounds perfectly normal....for a rod bearing that's failed. just joking, it's normal. That's the diesel part of these engines.
    usmc2msu likes this.
