Engine knocking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dady83, Jul 12, 2023.
  1. Jul 12, 2023 at 2:49 PM
    Dady83
    Dady83 [OP] Well-Known Member
    2020 Tacoma SR5
    Hey fellas, I got a question, tacoma 2020 only 15k miles and sometimes the engine knocks when ascending and in between gears (auto trans) , it does it for a bit and not always, for that mileage I would say is related with fuel but I'm putting regular gas like everyone and according to the manual 87 should be good. Any thoughts thanks in advance
  2. Jul 12, 2023 at 2:55 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Could be fuel. I use 87 all the time here with E10 in my 2020 v6, never hear any knocking issues while driving. You can hear diesel like noise's when idling if you listen well.
  3. Jul 12, 2023 at 3:00 PM
    Dady83
    2020 Tacoma SR5
    It's something sort of new and not always only when ascending with this mileage I wouldn't think is something different I treat it like my wife Lol
  4. Jul 12, 2023 at 3:01 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    It is "normal" for your driving environment. It pings on Premium as well. Tune it If interested to fix pinging.
    TRDRed and whiseve like this.
  5. Jul 12, 2023 at 3:22 PM
    zoo truck
    None
    Either the op's engine is tuned much different than mine, or its a case of less that good fuel. I can tell you when I was once out in the mid west with my 93 Toyota, the fuel sucked compared to what we have here.
  6. Jul 12, 2023 at 3:29 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    For what it’s worth, I don’t remember my 2016 v6 AT ever knock and I’ve only heard my 2020 v6 MT knock in rare extreme conditions (eg killing the engine due to user error). I always run 87 octane and have no engine mods.
    I believe you can attach a device to your engine and get logs of engine knock events. It’s likely more reliable than the human ear and you might gain other information about engine behavior.
  7. Jul 12, 2023 at 3:35 PM
    Scotfree
    Scotfree I drive slow
    2021 sr 4x4 2.7
    Check your fluid levels and air filter and run a tank of premium shell, add a bottle of Lucas oil injector cleaner to a full tank of gas. Take baby steps first.
  8. Jul 12, 2023 at 3:42 PM
    Vlady
    Issy, WA
    The auditable knock is around -6 on Knock Feedback sensor. -6 , -7 values are common when in 6th and the speed is above 60 mph. You need to plug OBDII tools to see the whole picture.
    whiseve, RustyGreen and Scotfree like this.
  9. Jul 21, 2023 at 12:20 PM
    whiseve
    whiseve Active Member
    Ohio
    '21 DCSB 6MT Voodoo Blue
    Mine pings on throttle tip-out (letting off the gas) between 2000 and 2500 rpm when the engine is fully warmed up. I encounter it after cresting a hill at 40 mph in 4th (about 2000 rpm) when easing partially off the gas. I'm using maybe half the torque that's available. It is probably the same as when the engine reduces output during the upshift of an automatic transmission to provide a smooth shift. There's no knock when actually pulling, only on tip-out afterward.
    It does seem to be an issue with the factory tune. Premium fuel increases the initial load required to replicate the issue, but it does not eliminate it.
    I don't hear more than extremely light, barely audible occasional pinging under any other situation.
    Dady83[QUOTED][OP] likes this.
  10. Jul 21, 2023 at 12:41 PM
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    This is my experience as well.
    whiseve[QUOTED] likes this.
  11. Aug 14, 2023 at 1:48 PM
    Tacolimited2021
    Tacolimited2021 New Member
    2021 zlimiteddouble cab long bed - army green
    Same thing with our 2021. I had it checked at the 10k service-nothing found. I’m about to take it in for the 20k service and have them check it again. Just wanted it on record. Did notice that running 89 octane calms it down.
    Shelf Life likes this.
  12. Aug 14, 2023 at 2:38 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    89 octane and up will calm that down . Just for the hell of it run that and see if it goes away
  13. Aug 14, 2023 at 2:52 PM
    InThePlains
    InThePlains Well-Known Member
    Cleaning cycle?
  14. Aug 14, 2023 at 7:16 PM
    whiseve
    Ohio
    No, this is under load at throttle tip-out, not at idle. Wish I had a mic to put under the hood capture it.
  15. Aug 14, 2023 at 7:33 PM
    Buckfat
    Buckfat Well-Known Member
    N GA
    2019 DCSB OR
    It’s Diesel mode! Watch the video I just posted.
  16. Aug 14, 2023 at 8:23 PM
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    Run 89 octane, change air filter, and change oil (making sure it’s GF-6A)
    whiseve likes this.
  17. Aug 15, 2023 at 4:17 AM
    TruckGuy63
    Gilbert
    New York
    It’s the timing trying adjust for the fuel, if you run higher octane it will totally go away, just to be safe bring it to the dealer and let them know exactly what’s going on . They will probably do nothing but at least it’s on record . No matter what people think , this motor likes higher octane they just computer adjust it to work with 87 octane .it will be quieter on higher octane
    cryptolime and whiseve like this.
  18. Aug 15, 2023 at 5:20 AM
    khine13
    khine13 Well-Known Member
    New Hampshire
    2022 MGM Pro Auto, 2002 SR5 DoubleCab (Sold)
    Lomax Tonneau Cover, Wildpeaks
    Anyone know if a tune removes this cycle?
  19. Aug 15, 2023 at 7:07 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Why would you tune out the cleaning cycle? That's doing a major dis-service to your intake valves...
  20. Aug 15, 2023 at 7:11 AM
    khine13
    New Hampshire
    That's not what I meant. I asked if a tune removes the cleaning cycle. Reason for my concern is that my truck is tuned. Thanks.
