engine leak...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Karo, Dec 15, 2010.
  1. Dec 15, 2010 at 2:43 PM
    Karo
    Karo [OP] Well-Known Member
    Karo
    La Crescenta, CA
    06 PreRunner TRD Sport
    Grill
    Hey ladies and gents I gotta question about an oil leak.
    What is the worst that can happen to my truck if I don't take care of this $700 fix for an engine leak?
    I have 93600 miles and just had my rear differential worked on since my earlier report of a "whining" sound coming from the middle section of the truck.
    Thanks for all of your wise words!
  2. Dec 15, 2010 at 2:52 PM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    Would need more info to let you know "WHAT" might happen. Oil is the life blood of the vehicle. No oil in truck... Truck go nowhere.. A new engine for close to 5-6 grand. Hmmm??? The more info we have the more we can tell you. :evil:
  3. Dec 15, 2010 at 3:07 PM
    Karo
    Karo
    La Crescenta, CA
    Grill
    If I don't see any oil where i park does that mean the leak is minimal for now? So I can save my money until I have enough to get it fixed
  4. Dec 15, 2010 at 3:11 PM
    toyotadude5
    toyotadude5 Breazeale- Pronounced Brazil
    chris
    Flagstaff, az
    2006 Subaru wrx sti (white)
    its not actually dripping out? I would say, obviously its better to get it fixed, but if its not a constant dripping out then just keep an eye on the oil level. Worst thing you can do is let it run out of oil, trust me i know haha
  5. Dec 15, 2010 at 3:14 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Constantly check your oil levels. Where and how did they say it was leaking?
  6. Dec 15, 2010 at 3:46 PM
    romafern
    romafern Well-Known Member
    Rob
    Olympia, WA
    stock and very pissed about the issues
    Machine gun mount. Would love to blow the shit out of it since it has nothing but issues. QA at Toyota USA is shit. Start making them in Japan for Christ's Sake!
  7. Dec 15, 2010 at 3:53 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I just got my TSB done for my oil leak. It was the timing cover that they had to replace. There is actually a good number of trucks on here that had this same problem. They also swapped out my water pump cause it was slightly leaking as well so I'm glad they caught that.:cool: But then again your over warranty so I'm not sure what you can do but pay out of your own pocket to get it fixed.
  8. Dec 15, 2010 at 3:55 PM
    Karo
    Karo
    La Crescenta, CA
    Grill
    I don't have any idea where its leaking since the dealer told me about it. I don't have any pics either but I can take one I suppose. Should I take a general pic from underneath the hood?
  9. Dec 15, 2010 at 4:17 PM
    WCJR
    WCJR Well-Known Member
    W
    I FOUND A LEAK SEALER THAT HAS WORKED ON A FORD F350 DIESEL WITH MULTIPLE LEAKS. IT STOPPED ALL THE ENGINE LEAKS EXCEPT THE ONE AT THE DIPSTICK PLASTIC FITTING. IT ALSO STOPPED A LEAK ON MY JDEERE 5410 TRACTOR. IT WORKS ON THE SEALS.
    THE WEB SITE IS SEAL LUBE. COM OR GOOGLE SEALLUBE. THEY ARE LOCATED IN MICHIGAN. I JUST BOUGHT 4 MORE BOTTLES FOR BACKUP.
    HOPE THIS HELPS.
  10. Dec 15, 2010 at 4:21 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Did the dealer say where the leak was coming from? If it were my truck I wouldn't have left there without them at least showing me what they were talking about...
  11. Dec 15, 2010 at 4:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    DO NOT use this on the 1GR-FE engine. There is NO evidence proving it is safe for use in an egine with variable valve timing.
  12. Dec 15, 2010 at 4:41 PM
    romafern
    Rob
    Olympia, WA
    OP, you need to get aggressive and find this leak. Do you see any oil "sweating" from the engine? Any wet spots? Or is the dealer just giving yu some bs to replace something for nothing?????
    It is time to get to know your rig. Change your clothes and put some old ones and get dirty with your rig. Find that leak and return to us with your findings.
  13. Dec 16, 2010 at 12:12 PM
    joerussell610
    Him
    Do not use any type of sealer on this or any other engine. They tend to clog up somethings that are not meant to clog. Those are ok if stuck in the middle of nowhere. Even then i'd start walking. Seen lots of evidence of what those thungs can do. Fix the vehicle properly. :crapstorm:
  14. Dec 16, 2010 at 12:27 PM
    Mod
    Mod Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    If the dealership (or any shop for that matter) just said you had a oil leak without explaining IN DETAIL where it was coming from, I would never go back there again.
    Get a second opinion somewhere else.
  15. Dec 16, 2010 at 7:25 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Worst thing that can happen is it gets worse rapidly and blows all the oil out while you're driving then the engine blows up.
    If it's the timing cover leak, I doubt that would happen. Just keep it full of oil and you're okay. But there are other things that could be leaking that can go from not so bad to blown engine real quick. For example, an loose oil filter.
  16. Dec 16, 2010 at 7:28 PM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    sounds like someone needs to buy a dye and light kit!
  17. Dec 17, 2010 at 4:52 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    That's real interesting...I had no idea these leak stopper products were effective at stopping any leaks, let alone something inside the engine they aren't supposed to. But then I never use them anyway:eek:.
    Any idea which kinds in particular to avoid?
  18. Dec 17, 2010 at 4:56 AM
    Hellmutt
    Hellmutt Well-Known Member
    Piqua, Ohio
    '08 SR5 TRDsport 4x4 DC
    sadly, I've only put Husky Liners in it thus far - tend to blow all my cash on my bikes and guitars.
    $700 oil leak repair?!?!?! WTF?!?!? Is it the rear main seal then? That seems an outrageous amount unless they have to drop the engine to repair the leak
  19. Dec 17, 2010 at 10:37 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    I just had to have my front main seal and harmonic balancer replaced.. that ran me about $550 so it may not be out of line to pay $700.
    OP you need to find out where its leaking from and constantly check the oil levels till you get it fixed
