Engine Life?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rockbug63, Oct 4, 2010.
  1. Oct 4, 2010 at 1:15 PM
    rockbug63
    rockbug63 [OP] Active Member
    central coast CA
    '09 Dbl cab 4x4 SR5 tow pkg.
    Rear leaf and steering column chatter tsb blower mtr replaced(waste of time) 2nd blw. mtr.; new headlights from DRL melt issue new water pump9 leaking0around block) pwr steering rack leaks, right frt. wheel bearing bad.
    How long do you think the 2nd gen 4.0L motor will last under normal use? I know that it has a new sleeved block that is supposedly non-rebuildable, but even my first '77 22R Hilux pickup went forever. Any CREDIBLE comments?
    P.S. I have a friend who has older Toyota station wagon thats a 4x4 and a few rebuilds later he's at 479,000 and a daily driver!
    I'm the same type of person, I'll have this truck till the wheels fall off, would have kept my '96 Taco 4 ever only my son came back from Germany needing a vehicle and I did what a Dad does best.
  2. Oct 4, 2010 at 1:43 PM
    brians05taco
    brians05taco Well-Known Member
    Brian
    Lafayette,La.
    05 prerunner white debadged 4.0
    lifted, bedcover,BHLM, grill, etc...
    87000 miles and counting
  3. Oct 4, 2010 at 1:44 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    billion
  4. Oct 4, 2010 at 2:03 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    my first engine only lasted 27,000 miles. But there is a story for that.
    Under normal use probably forever.
  5. Oct 4, 2010 at 2:12 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    we need the story dude...:D
    OP, 300k sounds about right under normal use.
  6. Oct 4, 2010 at 2:14 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    41,ooo and counting
    07 4.0L
  7. Oct 4, 2010 at 2:19 PM
    theredofshaw
    theredofshaw Well-Known Member
    Reno/Sparks, NV
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    yes we do...lol
  8. Oct 4, 2010 at 2:40 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    FourrrrrrrrrrrrrrrrrEeeeeeevvvvvveeeeerrrr
  9. Oct 4, 2010 at 4:15 PM
    pmo
    pmo Well-Known Member
    Nova Scotia Canada
    2007 Tacoma 4x4, DC, 6 Speed Manual.
    92000 kms=57000miles...still good!!!!
  10. Oct 4, 2010 at 4:15 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    I remember when the new hyundai alpha engine went out (for the new accent models, with ''vvti''), they said that the engine was rated for a 400 000KM lifetime so that is 250 000 miles of normal use on normal oil.
    I guess the toyota engine would go far beyond that.
  11. Oct 4, 2010 at 4:16 PM
    2gtacoma
    2gtacoma Well-Known Member
    Daniel
    H-town
    05 -PreRunner sr5
    URD Maf Cal, Airaid intake, Gibson exhaust, Urd short shifter,Trd shift knob, 2.25 lift,Satoshi grill, Trex eyelids
    im at 159,679 still running strong
  12. Oct 4, 2010 at 4:18 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    ive seen a 350k miles it was a thread about a week ago.
  13. Oct 4, 2010 at 4:19 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    It's a Toyota Motor dude. It's going to run to at least 250,000mi as long as you do the scheduled maintenance. That's a minimum. In reality, it will probably do 300,000+ if you even keep it that long.
  14. Oct 4, 2010 at 4:21 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    250000-300000miles with synthetic oil. That's for engine internals... Rod bearings, main bearings, piston rings. Stuff which when it breaks, usually requires engine rebuild.
    The main cause of engine deaths are failed rod bearings, which make wonderful knocking sound aka "death knock" and that is usually caused by not changing oil regularly or running the engine low on oil.
  15. Oct 4, 2010 at 4:22 PM
    07trd4x4
    07trd4x4 Well-Known Member
    Greg
    Truckee/Sacramento CA
    LX570
    Sleeves in the block!?!?
    Is that true!?!?
  16. Oct 4, 2010 at 4:23 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    I don't think anyone really knows the answer to that, every truck will have a different engine life.
    Use good oil and right oil, change it when it needs changing, use good filters, and don't abuse the motor.
    You'll sell it or trade up, before it goes bad.....if I were to guess.
    Hope that helps.
  17. Oct 4, 2010 at 5:11 PM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    This.
  18. Oct 12, 2010 at 1:12 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    It ain't been round long enough to say has it?
  19. Oct 12, 2010 at 1:22 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    Thats an interesting question, i have been wondering the same thing. I wanna keep my truck till it falls apart. 250xxx sounds good to me. Heck ive had it 5 years and it barely has 50k on it. it will last a lifetime with me.
  20. Oct 12, 2010 at 2:09 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Longer than the frame.
