Engine light and Trac light on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Squirrellydw, Sep 8, 2016.
  1. Sep 8, 2016 at 12:15 PM
    Squirrellydw
    Squirrellydw [OP] Well-Known Member
    2012 PreRunner TRD Sport
    my engine light and trac light just came on Amy idea what it might be. Truck still seems to run fine no noise or power loss. Going to get it looked at next week when I'm back home.
  2. Sep 8, 2016 at 12:16 PM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    Did you hit Trac off button by accident?
    That's the only time mine ever comes on.
  3. Sep 8, 2016 at 12:22 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    If your check engine light is on, you have thrown a code. Go to any autoparts store and borrow their code reader for free, and check what it is. No need to take your truck in and be charged $100+ to pull the code. Without having a code to go from, I'd guess you either have a check engine light and bumped your TRAC button (try pressing it and seeing if the TRAC light goes off), or you have some sort of ABS/TRAC sensor fault that is causing the system to be disabled, causing the check engine light and the TRAC light.
    10trdtaco likes this.
  4. Sep 8, 2016 at 12:23 PM
    atrain20210
    atrain20210 Active Member
    Aaron
    Vermont
    07 Tacoma TRD Off-Road
    Oil catch can, DIY aux input, 7 Pin trailer plug relocate
    Mine came on awhile back and it was a loose Gas cap. But could be a big range of issues
  5. Sep 8, 2016 at 12:24 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    90% of time? This^ check cap, if loose, tighten unhook battery for few minutes.
  6. Sep 8, 2016 at 12:29 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Loose cap would not cause the TRAC light to come on. It would throw an evaporative emissions leak code.
  7. Sep 8, 2016 at 12:30 PM
    IronPeak
    AuggieX
    Back to Back
    Loose cap does indeed cause trac light to come on.
  8. Sep 8, 2016 at 12:33 PM
    eon_blue
    Azusa, CA
    I get how a loose gas cap will make the CEL come on but what does it have to do with the TRAC light coming on? Not saying it isn't true just wondering why since it doesn't seem like they would be related to one another at all
  9. Sep 8, 2016 at 12:33 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I can't say from experience on the Tacoma. But that surprises me as the systems are unrelated.
  10. Sep 8, 2016 at 12:43 PM
    IronPeak
    AuggieX
    Back to Back
    Without getting into the direct cause and effect aspect, trac comes on by default with CEL when cap loose at least in later 2nd gens
  11. Sep 8, 2016 at 12:44 PM
    Squirrellydw
    Here is a pic
  12. Sep 8, 2016 at 12:46 PM
    IronPeak
    AuggieX
    Back to Back
    Did you check the gas cap? If it can spin and click it was loose. If not some other reason for CEL TRAC new caps are single click fyi
  13. Sep 8, 2016 at 12:47 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Check your gas cap.
    Aside from that, I had this happen in my truck earlier this year completely out of the blue. It disappeared an hour later on it's own and hasn't come back.
    IronPeak likes this.
  14. Sep 8, 2016 at 12:47 PM
    Squirrellydw
    Not the gas cap. Just tried it. Took it off and put it back on started the truck still on
  15. Sep 8, 2016 at 12:47 PM
    98tacoma27
    Ben
    Not Beech Creek
    That's kind of the point...
    IronPeak[QUOTED] likes this.
  16. Sep 8, 2016 at 12:47 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Does so
  17. Sep 8, 2016 at 12:48 PM
    OZ-T
    Peter North
    British Columbia
    You need to have the code cleared
  18. Sep 8, 2016 at 12:48 PM
    OZ-T
    Peter North
    British Columbia
    Yes
  19. Sep 8, 2016 at 12:50 PM
    IronPeak
    AuggieX
    Back to Back
    I siphoned gas off my roof rack recently and failed to click cap. threw CEL TRAC unhooking batt cleared
  20. Sep 8, 2016 at 12:52 PM
    IronPeak
    AuggieX
    Back to Back
    It may not be the cap then. If you are basing that it is not the cap just by closing, closing cap will not clear code, even if you drive a bunch of miles. Older cars would clear self after sensing correct pressure in tank for a period of time, not tacos
