Engine light and Trac light on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Squirrellydw, Sep 8, 2016.
  1. Sep 8, 2016 at 12:57 PM
    Squirrellydw
    Squirrellydw [OP] Well-Known Member
    2012 PreRunner TRD Sport
    Could it be something else more serious? I will get it checked when I get back and get the code
    IronPeak likes this.
  2. Sep 8, 2016 at 12:58 PM
    eon_blue
    Azusa, CA
    yeah just run it over to auto zone or pep boys and have them pull the code for free, post it up here and someone will surely have had some experience with it.
    If the check engine light is solid and isn't flashing then it's not likely an issue that requires immediate attention (as in, skip getting the code pulled at Pep Boys and take it to the shop right now).
  3. Sep 8, 2016 at 1:01 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Wouldn't mind a couple 2-3 Guerneville taco truck tacos right meow..
  4. Sep 8, 2016 at 1:03 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Does it engage four wheel drive? If no, you most likely have a bad wheel speed sensor. ABS braking won't occur either.
  5. Sep 8, 2016 at 1:13 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Thanks, I like getting right to the point..:)
  6. Sep 8, 2016 at 1:15 PM
    IronPeak
    AuggieX
    Back to Back
    3 tacoz sez it's the cap, p.s. I've been enjoying that truck for 20 yrs, with a decade gap in there somewhere...
    T4RFTMFW[QUOTED] likes this.
  7. Sep 8, 2016 at 1:23 PM
    Squirrellydw
    check engine light is solid not flashing and it's a prerunner so no 4x4, that will be in my next truck in about 2 years.
  8. Sep 8, 2016 at 1:23 PM
    IronPeak
    AuggieX
    Back to Back
    Another question did you gas up within the last 25 miles?
  9. Sep 8, 2016 at 1:25 PM
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    There is also the issue with the intake exhaust plate thing that toyota won't cover on a recall. Can't remember what the thread was called. I know the 4R and the tundra had the issue. @slcsez2000 ? I think most of them were going into limp mode though
  10. Sep 8, 2016 at 1:26 PM
    Squirrellydw
    No not even close. Had one hell of a storm here the other night and today is the first time I noticed it.
  11. Sep 8, 2016 at 1:28 PM
    mosquitoTaco
    Anthony
    SouthTennessee
  12. Sep 8, 2016 at 1:32 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    This is all speculation. Pulling the code (for free) will provide the real answer.
  13. Sep 8, 2016 at 1:32 PM
    JDAM
    JDAM Well-Known Member
    J
    Worshington
    12 DCSB TRD OR
    This happened to me. Broke an ABS speed sensor and was around $150 for a replacement sensor.
  14. Sep 8, 2016 at 1:37 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Holy balls, thank you, someone finally said it. It could be your engine is about to explode!!!!!! Nobody knows anything until you get the code checked, OP. Come back with the code numbers or if Vatozone can tell you what the codes mean, and let us know.
    crashnburn80[QUOTED] likes this.
  15. Sep 8, 2016 at 1:43 PM
    #35
    Squirrellydw
    It's already been said before this post and I will when I get it.
  16. Sep 8, 2016 at 1:54 PM
    #36
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Yes
    Jimmyh and IronPeak like this.
  17. Sep 8, 2016 at 6:03 PM
    #37
    IronPeak
    AuggieX
    Back to Back
    Define "vato" for us pls
  18. Sep 8, 2016 at 6:08 PM
    #38
    VolcomTacoma
    Jeff
    NorCal
  19. Sep 9, 2016 at 1:20 AM
    #39
    Realoldfatguy
    Realoldfatguy Well-Known Member
    Bob
    Iowa
    2017 DCSB TRD OR MT QUICKSAND
    RokBlokz Rally Flaps Toyota running boards
    I have a 2010 Prerunner that was doing a similar thing (CEL and Skid Indicator). Pulled the codes, which showed "evaporative" something or another. This was the second time this showed up in about a week, so I took the gas cap off, cleaned it along with where it screws in. Cleared the codes and it has not shown up since.
  20. Sep 11, 2016 at 3:42 PM
    #40
    Squirrellydw
    Just a little update. I couldn't pull my 750lb trailer today. It seemed like I had very little power and couldn't go over 40mph. Took it off and truck ran fine and came home. Getting the code Monday hopefully
