engine light and trac light on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by homertheory, Jul 7, 2017.
  1. Jul 7, 2017 at 9:37 AM
    homertheory
    homertheory [OP] Member
    kurt
    canmore ab
    tacoma trd
    does any one know why the trac off and engine light would come on. it idles just fine and tightened the gas cap. took the leads off of the battery posts for one hour and the lights still come back.
    ChadsPride likes this.
  2. Jul 7, 2017 at 9:42 AM
    JoefromPTC
    JoefromPTC Well-Known Member
    Joe
    Atlanta Georgia metro
    2005 Tacoma TRD Sport 4X4 6MT
    Could be many things... What codes are you getting from the CIL?
    BassAckwards and ChadsPride like this.
  3. Jul 7, 2017 at 9:43 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    The ecu is more than likely throwing a code of some sort. If you get a code reader or go to auto zone and have them read the code for you, someone can chime in with better advice! Good luck!
    HutchJ and ChadsPride like this.
  4. Jul 7, 2017 at 9:59 AM
    jokker1978
    jokker1978 Well-Known Member
    southeast texas
    2012 TRD sport 4dr 4x4 white
    What year is it?
    And is it in limp mode?
  5. Jul 7, 2017 at 10:15 AM
    homertheory
    kurt
    canmore ab
    tacoma trd
    it drives at normal speed and rpm its a 2012
  6. Jul 7, 2017 at 10:37 AM
    jokker1978
    southeast texas
    Go get the codes pulled
  7. Jul 7, 2017 at 10:41 AM
    Clearwater Bill
    Billy
    Largo Florida
    Buy a SCII, Ultragauge, or the Torque app and a dongle.
    Read and clear your own codes next time.
  8. Jul 7, 2017 at 10:44 AM
    eon_blue
    Azusa, CA
    +1 on the Torque app.
    $4.99 for the app on your phone and +/- $30 for a bluetooth/wi-fi OBDII plug-in. Just open up the app, scan for codes and go from there. Plus with the Torque app you can monitor all the things a Scangauge does as well (engine/intake/transmission temps, AFR ratio, sensor readings, etc.).
    Only thing that sucks about it is it drains your phone battery like crazy. At least it does on mine.
    JoefromPTC, llamasmurf and jokker1978 like this.
  9. Jul 7, 2017 at 11:18 AM
    Clearwater Bill
    Billy
    Largo Florida
    I agree if all you want is a hand held scanner of sorts.
    I personally don't care for it as a monitor, because it keeps the phone tied up and the battery hit as you mention.
    But it is a good inexpensive reader option.
    SCII is my go to for a semi permanent mount. Have one in each vehicle. They are at least interesting on road trips if not needed operationally for the vehicle. And I do like seeing that trans temp........ makes you feel good. :cool:
    eon_blue[QUOTED] likes this.
  10. Jul 7, 2017 at 11:41 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    The little otc/Matco pocket reader is a good deal. Also they have some higher end models for obd codes, abs and air bag. Autozone will read the code for free and try to sell you the part they think will fix it. This is not a diagnostic. Best to just get the code pulled and report back.
  11. Jul 7, 2017 at 12:25 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Since I have owned my truck, just over 1 1/2 years. I have had this happen twice.
    The 1st time it was winter, I was turning left and it was icey. I gave a little to much throttle and got the back end loose, traction control kicked in and straightened the truck out. Then the exact lights you have one turned on for me. Used Torque app on my phone when I got home and reset the codes with my OBDII bluetooth device that is always in the truck. Lights did not come back on so I figured it was just a fluke with the traction control throttling the engine and such.
    2nd time was just random, pulled up to a stop light, no dash lights. Light turns green and I pull away, both lights are on. Same thing, get home use Torque and OBDII bluetooth device, reset codes. Gone and have not come back.
    I decided if it happens again, it will see the dealership and they can tell me why my brand new truck is pooping itself.
  12. Jul 8, 2017 at 11:21 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Trac light usually means wheel speed sensor issue. Probably the wires leading too.
    The trac system can also be calibrated. Look up the zero point calibration.
    Also, you can check your code by jumpering leads on your obd2 port.
    Lastly, use the search feature. This topic has been discussed many times and lots of info is on there already
