Engine Light on after welding on truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pake13, Apr 4, 2015.
  1. Apr 4, 2015 at 7:00 PM
    Pake13
    Pake13 [OP] Well-Known Member
    Pake
    SouthEast Texas
    '11 Tx Pro DCSB,
    Debadged, OME 886 Coilovers, Dakar leafs, All Pro Bed Rack, etc.
    I forgot to disconnect the battery before I tacked two welds on my front bumper, and when I started it up again, everything worked fine, but the Engine light and abs light right under are lit up. Have I fried the ECU or is there something else that could be wrong.
  2. Apr 4, 2015 at 7:05 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Disconnect the battery and see if things go back to normal. I've welded on vehicles plenty of times with the battery hooked up.
  3. Apr 4, 2015 at 7:05 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    whats the code thats stored?
    unplug the battery for 30 min to an hour and see if it comes back.
  4. Apr 4, 2015 at 7:05 PM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Yikes. I've never disconnected my battery when welding and I've been fine... :notsure:
  5. Apr 4, 2015 at 7:06 PM
    XXX
    XXX Member
    Cedar City, UT
    06 DC
    What kind of welding with what power of welder? What year of truck? I just welded some sliders on to my truck, I was using a friends shop and he said I didn't need to disconnect the battery. He said he welds stuff on to jeeps and buggys without disconnecting the battery. He's a really well known and reputable builder too.
    I still would just to be safe. Luckily I didn't have any issues, the only reason I didn't disconnect is because he said I didn't need to and I would've felt rude disconnecting my battery in front of him.
    At any rate, check the codes with a scan tool and go from there.
  6. Apr 4, 2015 at 7:18 PM
    Pake13
    Pake
    SouthEast Texas
    '11 Tx Pro DCSB,
    Mig welded, Miller 212 at 7-8 voltage (3/16") on my 2011 Tacoma. Disconnected battery, now waiting for half and hour.
  7. Apr 4, 2015 at 7:25 PM
    XXX
    XXX Member
    Cedar City, UT
    06 DC
    Yeah, that's what I was using. My friend said he TIG welds on cars and he has to take the battery out and disconnect the ecu from the frame so it's not even touching. I don't know if that's even necessary or just required of him because he is a mechanic on the Redbull Global Rallycross team, so the consequences are pretty heavy if they fry anything.
  8. Apr 4, 2015 at 7:51 PM
    Pake13
    Pake
    SouthEast Texas
    '11 Tx Pro DCSB,
    After going through every fuse, and every online article on ecu's and batteries, I found the problem. My brother, who was helping me with my job, replaced a blown Fog light fuse with the efi 2 fuse which he thought was a spare.
  9. Apr 4, 2015 at 7:53 PM
    koditten
    Kirk
    Central Michigan
    That is funny. Glad its fixed.
  10. Apr 4, 2015 at 7:53 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    hahaha Classic friend help
