engine light on help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ernest2700, Aug 9, 2016.
  1. Aug 9, 2016 at 3:22 PM
    ernest2700
    ernest2700 [OP] Member
    Indiana
    14' Black Tacoma access cab
    K&N air filter, basically stock until funds come around.
    My engine light is on after pulling a relay to test my fog lights. My truck is a v6 4x4 access cab, year 2014. I didn't turn the engine on just the battery during testing and the result is an engine light and traction control light. I used a traction control relay to test the lights, which work great, but do you think I torched that relay swapping it from one place to another? Even with not turning the motor over at all.
  2. Aug 11, 2016 at 5:33 AM
    ernest2700
    Indiana
    Fixed it! relay code.
  3. Aug 11, 2016 at 3:58 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    No you didn't harm anything. The code was thrown for Traction Control when you turned on the ignition switch with the relay out...
