engine light on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by alpoitras, May 13, 2012.
  1. May 13, 2012 at 6:17 PM
    alpoitras
    alpoitras [OP] New Member
    o6 tacoma, had scanned got code po138.(02 circut high voltage bank 1 sensor 2) changed sensor 2. engine light came back on after about 80 miles. this happened about 8 times the code was erased each time. Thought I had a defective sensor so I brought it back and replaced with another. Same problem. Any one have any ideas ? Thanks
  2. May 13, 2012 at 6:27 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Sometimes the sensors are reporting the correct information and you actually are sensing something wrong.
    They are not there simply to generate codes and cost you money.
    Could be a bad cat or mixture is off.
