Engine Light P0420 code ???
Discussion in '1st Gen. Tacomas (1995-2004)' started by hillinsan, Dec 14, 2013.
  1. Dec 14, 2013 at 3:07 PM
    hillinsan
    hillinsan [OP] Active Member
    Beavercreek,OR
    tacoma 4wd TRD
    So my engine light has came on, gone away and is now back again.
    The code is P0420
    probable cause reads:
    1. Air leak in exhaust before rear HO2S
    (Heated oxygen sensor) Bank 1
    2. AF sensor error
    3. Fuel system fault
    4. Faulty Catalytic converter
    Any input from you guys would help out a lot if you have had this problem. Dont want to just start replacing with out an educated guess.
  2. Dec 16, 2013 at 6:49 AM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    I had that code for a while on my 96 Tacoma. I went through the steps of changing all the exhaust gaskets, looking for leaks and what not. That didnt help me. I changed out the o2 sensor and that fixed my code. You may still want to look for leaks though...
  3. Dec 16, 2013 at 7:20 AM
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    Check it
  4. Dec 16, 2013 at 7:52 AM
    Inverno4
    Inverno4 Well-Known Member
    Baltimore, MD
    2020 DC Off-Road MT
    Mine was on this past summer. Checked everything rigorously for leaks. Bought a new Denso O2 sensor, problem solved.
  5. Dec 20, 2013 at 9:27 AM
    hillinsan
    Beavercreek,OR
    tacoma 4wd TRD
    Ok guys, I just changed out the oxygen sensor and when I started the truck the light was still on. Do I need to reset the engine light by removing the neg battery? I hope so I need to get through DEQ in the next day or I will have to buy another trip permit. :(
  6. Dec 20, 2013 at 9:33 AM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    I'd reset it. I had to replace both o2 sensors on my old truck.. It should clear itself eventually but resetting will be faster. If you still have a problem it'll come back on.
    You will likely need to drive for a while for all the monitors to show "ready" - unsure if Oregon will fail you but many places require monitors to all be ready.
  7. Dec 20, 2013 at 9:52 AM
    hillinsan
    Beavercreek,OR
    tacoma 4wd TRD
    Ok thats what I was thinking, I reset it before I went and bought the sensor and went through deq but it wasnt ready yet. Was trying to cheat because ive done it before with an older car. I'll try to reset but hopefully it doesnt come back on and the sensor is indeed the problem
  8. Dec 20, 2013 at 9:55 AM
    fyremanpat
    fyremanpat Well-Known Member
    Pat
    757
    2013 DC LB TRD Sport w/Entune
    OME 886x and 5100's all the way around. Toytec AAL. Phillips x-treme vision headlights. 886 reverse lights. Borla exhaust. 20% tint. Hi 6 mod. 285/65/18 Nitto TG on 18" Moto Metal 955's. Airaid intake. Scanguage2.JBA LT's.GC Grill..more to come.
    clean your MAF....im willing to bet it will get rid of your code. I spent a fortune one time trying to clear that code...new o2's, new cat, etc...an $8 can of CRC Maf cleaner did the trick
  9. Dec 20, 2013 at 10:45 AM
    02goldie
    02goldie Well-Known Member
    Brock
    Lenoir, NC
    2016 Sport DCSB 4x4
    OME lift, spidertrax, 285 duratracs
    when mine came on, it was because of a bad cat. so i installed a URD O2 sensor simulator and deleted the rear cat completely. no check engine light on since. just an idea
  10. Dec 21, 2013 at 3:14 PM
    hillinsan
    Beavercreek,OR
    tacoma 4wd TRD
    Thank you guys for all the Help!!! The Denso 02 sensor fixed the problem. I had to reset the engine light with the neg battery wire and drove it all over hell yesterday and it passed DEQ. Thank you again.
  11. May 26, 2014 at 10:04 AM
    Andyd103
    Andyd103 Well-Known Member
    Andrew
    New Hampshire
    2002 Tacoma SR5 4WD (3.4L V6)
    Suspension Lift, 40mm Turbo
    an exhaust leak after the cat caused my P0420 so it's more than possible, 125,000 on the sensor.
