Engine light with P0606, P0420, and P0430 codes.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by will84, Feb 25, 2020.
  1. Feb 25, 2020 at 9:31 AM
    will84
    will84 [OP] Active Member
    Will
    2005 Green Tacoma
    I just bought an 05 Tacoma. I took a risk and bought it with an engine light on. The seller said it was an o2 sensor and having a diagnostic scan confirmed that. So I replaced the o2 sensor that was showing bad. The light went off for a while but then about 30 minutes later came back on. I had it scanned again, and now these codes are showing:
    The recommendation from the Autozone system says the P0420 and P04230 could be an exhaust leak, AF sensor error, fuel system fault, or a bad cat.
    There was really no recommendations for the P0606 code.
    Anyone have similar issues?
  2. Feb 25, 2020 at 5:06 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
