Engine light's on but nobody home...
Discussion in '4 Cylinder' started by wanoyee, Feb 25, 2010.
  1. Feb 25, 2010 at 8:33 PM
    wanoyee
    wanoyee [OP] Member
    My check engine light just came on today... but I don't see anything wrong. I checked the oil, the coolant, looked around and didn't see anything smoking or hear any funny noises. Could this be an O2 sensor or a "take me in because of the mileage" thing? It actually came on then went out... for a while. Now it's on all the time. I only have about 82500 miles. My Taco is an '04 Extended Cab 2.7 4-wheel drive. Any thoughts? Thanks!
  2. Feb 25, 2010 at 8:35 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    take it to autozone and have them hook up a diagnostics reader to it. the code will show on the screen and then they will tell you in words what the code reads and go from there!
    good luck!
  3. Feb 25, 2010 at 8:36 PM
    08pretaco
    az
    your way over on the eastcost, so go to a few auto parts stores and theyt should help you out :)
  4. Feb 25, 2010 at 8:40 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Get the code(s) pulled before you start guessing at what's wrong. It's the ONLY way to find out what's wrong.
  5. Feb 25, 2010 at 8:42 PM
    08pretaco
    az
    ^ whats another way to do that besides hooking up an obdII reader??
  6. Feb 25, 2010 at 9:07 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    There is none!
  7. Feb 25, 2010 at 10:06 PM
    08pretaco
    az
  8. Feb 4, 2011 at 2:50 PM
    frog13
    frog13 Well-Known Member
    Buy a scangauge II and you can use it in the future also..... all sorts of goodies with the scangauge II.
  9. Feb 6, 2011 at 6:26 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    X2. You can also use it for codes in other vehicles you or your friends and family might have.
  10. Feb 6, 2011 at 6:58 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    It could be anything, the things you are checking / looking for will not necessarily indicate what is actually wrong. It could be a bad sensor or the gas cap could be loose or leaking. The computers nowadays are so good that they can adjust their operation so you'll never "feel" what's wrong because the air/fuel mix is compensating for it but it is destroying your gas mileage or emmissions, for example.
