Engine Loose Power
Discussion in '2nd Gen. Tacomas (2005-2015)' started by raffy, Mar 12, 2010.
  1. Mar 12, 2010 at 9:55 AM
    raffy
    raffy [OP] Member
    Toronto
    08 TACOMA TRD
    Tacoma 4X4 Manual 2008 with 27600km - Merging into the hi-way at an speed of 80kph with 2000rpm. At this speed and rpm I can't encrease by pressing the gas pedal both the speed and RPM at 6-gear position. With this situation I full over into the shoulder to stop in motion while the enigne is at idle status. I open the hood and can't hear any uncommon sound and the idle rpm is at about 900rpm. So I merge again into the hi-way and it works good up to the speed of 120kph. Also at stop light stop and the engine is idle but it varies from 900 to 1200 rpm but my camry 1992 with 343000km has an stable rpm this situation the aircon is not "ON". Any idea is a great help and appreciation, thank you. Raffy
  2. Mar 12, 2010 at 9:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    If your still under waranty, Take it to the dealer.
  3. Mar 12, 2010 at 10:48 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Yes sir take it to the dealer!
