Engine lugging
Discussion in '1st Gen. Tacomas (1995-2004)' started by Steelersboy, Nov 16, 2010.
  1. Nov 16, 2010 at 12:33 AM
    Steelersboy
    Steelersboy [OP] New Member
    95 4x4 sr5
    6 inch fab tech 32 mtr's
    Hey I'm new here I have a 95 sr5 Tacoma that is missing bad feels like I'm to high of a gear whenever I accelerate I have All new coils new wires and plugs and a new air and fuel filter but still isn't fixing the problem I also ran some sea foam injector cleaner through it any possible solutions would be much appreciated thanks
  2. Nov 16, 2010 at 5:44 AM
    WASTE MANAGEMENT
    WASTE MANAGEMENT Well-Known Member
    Travis
    Umatilla Florida
    97 tacoma 4x4 3.4 w/5 speed
    new 31x10.5 tires, mag wheels, drilled rotors, new sound, and a cb.
    Check the compression in each cyl. make sure they are all at least 90 P.S.I. thats min. you could have a valve sticking.
    Is it a 4 or 6 cyl?
  3. Nov 16, 2010 at 5:52 AM
    cab4you26
    cab4you26 Well-Known Member
    Corey
    VA
    97 Tacoma, 5spd 2.7L
    Wheelers Offroad black steel wheels, 12 disc changer, spray in bedliner, Black UWS toolbox, Kelly Safari TSR's, Dynomax Super Turbo
    Probably not likely but check for spark.
  4. Nov 16, 2010 at 9:53 PM
    Steelersboy
    95 4x4 sr5
    Thanks it's a 6 it actually was a hidden wire unrelated to the ignition system shorting out only block
  5. Nov 16, 2010 at 10:31 PM
    Mr.Fahrenheit
    Mr.Fahrenheit Dennis = sinneD
    American Canyon, California
    01 Taco 3.4L 5spd TRD
    K&N CAI, HUSKY LINERS, LOW PRO TOOL BOX, GRAY WIRE MOD, OPTIMA RED TOP, GOODRIDGE STEEL BRAKE LINES, FAB TECH LIFT,
    good find....
