engine misfires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bill’s TRD, Jan 16, 2022.
  1. Jan 16, 2022 at 3:42 PM
    Bill’s TRD
    Bill’s TRD [OP] Member
    2006Tacoma double cab 4x4 TRD off road
    My engine misfires off and on even after a tank of gas with Lucas fuel treatment was used and new spark plugs installed. I suspect an ignition coil is failing. Has anyone had a similar problem. 2006 Tacoma with 181k miles.
  2. Jan 16, 2022 at 3:49 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Are you getting any engine codes?
    Or are you feeling it at idle or under load?
    Bill’s TRD[OP] likes this.
  3. Jan 16, 2022 at 3:51 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Scan it.
  4. Jan 16, 2022 at 3:51 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Next step would be to figure out which cylinder is missing...
  5. Jan 16, 2022 at 4:07 PM
    Bill’s TRD
    Scanned by Auto Zone. Found nothing even though Check engine was on. I think I’ll have a complete engine scan. Kinda expensive.
  6. Jan 16, 2022 at 4:11 PM
    Bill’s TRD
    Misses sometimes at idle and when under load. This problem comes and goes. Maybe several hours, then starts again.
  7. Jan 16, 2022 at 4:21 PM
    Bill’s TRD
    I wish I knew a simple way to determine which cylinder misfires. A few years ago I had a SUN timing light that I could clamp on each plug wire for this test. Old school, when troubleshooting was simpler and you could do many repairs yourself. Being an old man (85 in March) doesn’t help.
    Steves104x4 likes this.
  8. Jan 16, 2022 at 4:27 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    There is but you need a scanner that can read enhanced engine data, misfire counts on each cylinder are available in scan data.
  9. Jan 16, 2022 at 7:01 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Get a buddy.
    Start truck
    And start unplugging one by one and listen for a difference in the engine
    If you pull one and it makes no difference in the idling. “There it is”
  10. Jan 16, 2022 at 7:16 PM
    Waasheem
    Waasheem
    2007 xrunner
    If they scanned it, found nothing while the check engine light is lit, they either did it wrong or used a really cheap code reader. Many places don’t charge to plug in a code reader.
  11. Jan 16, 2022 at 7:22 PM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    Agreed. Go to auto Zone, advanced auto NaPa…. Or any chain parts stores
    they all should scan for free
  12. Jan 16, 2022 at 7:24 PM
    Waasheem
    Waasheem
    2007 xrunner
  13. Jan 16, 2022 at 7:34 PM
    BamaHound
    BamaHound Active Member
    Bama
    2019 OffRoad DCSB 6sp manual
    3" Old Man EMU front / 1.5" aal rear, Step Bars, No Chrome
    May be a good investment to spend $140 on 6 new coils and a crank position censor. By the time my trucks get close to 200k I have 2 of everything. I can't stand casing codes and spending time worring with 1 part at the time when I need my truck
  14. Jan 16, 2022 at 8:03 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Lol you got the not cheap part right on the SnapOn, I have a Verus Pro (bought used in 2017 for $3000), a Verus Edge (used 2021 $3400), and an Autel MS906BT (new 2018 ~$2000).
    You can get a pretty capable scan tool nowdays for under $200, if you want full system scanning, data, and bidirectional controls your gona be in the $300-700 range.
    There's also some cheaper ones out there now that offer full system diagnostics subscriptions by vehicle Make for very reasonable prices.
  15. Jan 16, 2022 at 8:20 PM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    My 2005 would misfire (Buck) under a load. Under normal driving it was fine. I changed the plugs and it didn't help. I went back and checked each of the coils and found that one was burnt where it attached to the top of the plug. I ordered a new one through Rock Auto and haven't had a problem since. I am thinking I didn't get it on quite right on my last plug change. Around hitting the 10,000 mile mark it started acting up so I changed the plugs thinking I got a bad set.
