Engine Misfiring
Discussion in 'Technical Chat' started by loridacoastie, Nov 28, 2009.
  1. Nov 28, 2009 at 1:43 PM
    loridacoastie
    loridacoastie [OP] New Member
    My brand new V6, manual tacoma has been misfiring. When I took it in they told me that the #1 coil had backed out and it was a simple repair. The truck was running great again for a week then it started to have the same problem. I brought it back in and they replaced the #1 coil. However, it is still having a misfiring issue. They seem to think that there is water in the gas and that the water has been causing the coil to back out. They want to pull the engine apart and clean it up to get the water out. An engine tear down isn't covered in my warranty and I don't think that pulling the engine apart is going to accomplish anything anyways. Anybody have any ideas as to what the problem could be?
    The car has less than 5k miles on it.
  2. Nov 28, 2009 at 2:43 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    I'd go get a second opinion. I don't see the need to tear the engine down, if there's water in the fuel. That doesn't even make sense.
  3. Nov 28, 2009 at 2:53 PM
    98tacoma27
    Ben
    Not Beech Creek
    Times 2. That sounds totally absurd.
  4. Nov 28, 2009 at 8:40 PM
    btkicker
    btkicker Well-Known Member
    Denver
    '10 4x4 Reg Cab Manual
    Yep, go to another deal If that doesn't do it call the national toyota customer service line. The last thing they want is a lemon out there.
  5. Nov 28, 2009 at 8:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds like the plug might be having some "blow-by", causeing the coil to pop off the plug.....
  6. Nov 30, 2009 at 5:42 PM
    loridacoastie
    Thanks for the replies. I wasn't buying the water story either.
