Engine Miss at low idle only
Discussion in 'Technical Chat' started by dgilling, Jan 27, 2014.
  1. Jan 27, 2014 at 9:52 PM
    dgilling
    dgilling [OP] New Member
    Colorado
    01 Doublecab TRD 4x4
    3" AAL in Rear, Moog coil springs that lifted the front unintentional 3", Bilstien 4500 shocks
    My truck is basically all stock except I have the deck plate mod and a K&N drop in filter. When my truck is warmed up, I stop at a light, and the engine reaches it's lowest idle speed, there is a weird feeling. My dad called it a miss. the engine will just kind of shake and the rpm needle will move ever so slightly. I don't really know how else to explain it. It happens randomly and I don't really know what causes it to happen more or less. It might happen 2 or 3 times when I'm stopped at a light. The truck runs perfectly normal at speeds. I guess it seems underpowered going up a steep hill but I always figured that was normal for the small truck (kind of bogs down). Anyone have any thoughts? seems like it could be just about anything. Milage is typical ~17MPG.
    2001 V6 double cab
    Plugs are fairly new, 30k miles maybe
    drained gas and put in higher octane gas
    Cleaned Filter (still need to clean MAF, but I did at last interval)
  2. Jan 27, 2014 at 9:57 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Cleaning the MAF might help (especially with the K&N, it might be contaminated), but my '08 will "hiccup" every now and then. Not often.
    Could also be your PCV valve.
  3. Jan 27, 2014 at 10:00 PM
    Jetlander
    Jetlander Just trying to measure up...
    Jonathan (aka MOAB)
    Depends on the day.
    2010 Tacoma DCSB 4x4 SR5
    TKO Wheel w/ 35" BFG KM2, Volant CAI, Safari Snorkel, 3" lift, All-Pro Full Skid Underarmor, Chopped/Re-Routed FlowMaster Exhaust, CBI Moab 2.0 Front Bumper, DerpWerx High Clearance Rear Bumper, Rear Tire Swing Out, BAMF Sliders w/Kickouts, King Resi w/700# Coilovers on front, Total Chaos UCA's, King Long Travel with Resi's, Shock Hoops and King 2.5 Bump Stops, OME Dakar Leaf Springs mounted on All-Pro Shackle Flip w/ U-Bolt Flip, extended SS Brake Lines, DerpWerx Bedrack, 10# C02 Tank, Black Badges, Dual Optima Red Top's, Blue Sea 12 Fuse Block on custom Block mount, SuperWinch 9.5iSR Talon w/synthetic line, Prolink Thimble, 20" Rigid Dual Row LED Light Bar, Rigid Dually Floods, OTRATTW Switches, Cab Mount Chop, Cobra CB w/ 4' Firestik, Center Counsel Glock 23 mount (with plenty o' ammo!), Weathertechs, and plenty more mods to come!
    Yes… Change all of the spark plugs. It sounds like you have a bad one. That would be the easiest potential fix. Or you could just pull them all out and inspect/clean and put back in, but if you are going to go through the trouble of pulling them you might as well just change them out. Just my 2 cents…
    However, it could be something different altogether. Is it throwing a code?
  4. Jan 27, 2014 at 10:32 PM
    dgilling
    Colorado
    It's not throwing a code.
    I question if it could be the spark plugs. if it was, wouldn't I feel it more when I push on the gas?
    I did think about the PCV valve, that seems like an easy one to check and super cheap. My truck has 175k on it and I know it hasn't been replaced for 80k miles since I've owned it.
  5. Jan 27, 2014 at 10:49 PM
    Jetlander
    Jonathan (aka MOAB)
    Depends on the day.
    Definitely something to look at. Start cheap and hope for the best!
  6. Jan 28, 2014 at 7:34 PM
    dgilling
    Colorado
    I cleaned the MAF, it was pretty clean anyways. I pulled the PCV valve and checked the vacuum. The vacuum seemed strong with and without the valve and when I shook it, I could hear a rattle as expected. I replaced it anyways since a new one was only $4. Both didn't help. I did find a vacuum hose disconnected but it also didn't solve my issue. I guess next would be plugs but I just can't see how it could be those.
  7. Jan 28, 2014 at 7:37 PM
    Jetlander
    Jonathan (aka MOAB)
    Depends on the day.
    You'd be shocked. Give them a try.
    I had a plug with a small crack in the insulator and it gave me all kinds of engine roughness. Took me forever to find the problem, but when I finally did narrow it down I changed the plugs and the problems all went away.
