Engine Miss
Discussion in 'Technical Chat' started by Arkansas Taco, Feb 1, 2012.
  1. Feb 1, 2012 at 9:31 PM
    Arkansas Taco
    Arkansas Taco [OP] New Member
    Arkansas
    2000 Tacoma Xtracab V6 4x4
    I have my Son's 2000 Tacoma w/3.4 V6 I am working on.
    It has a miss and sometimes a backfire thru the exhaust ONLY after it has come up to operating temperature. When the engine is cold it seems to run fine.
    When cold the engine idles perfect and drives fine until it warms up.
    When warm, it misses at idle, also when building speed, but seems to smooth out at about 55 mph. If you try to build speed above a cruise speed the miss returns.
    The CEL stays on steady until the engine starts to miss then the CEL flashes.
    We have run the codes and came up with PO300, PO301, PO303, & PO306.
    We know what the codes mean and have changed the plugs and checked the compression (it was good) since reading the codes but no good results.
    I am hoping someone might give me info or opinion on this before I sink a ton of money into it unnecessarily.
    Thanks in advance for any help!
  2. Feb 1, 2012 at 9:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW. If no one helps you tonight, ill see what input I can give in the morning.
  3. Feb 2, 2012 at 6:02 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Arkansas,
    Do you know if and when the timing belt and idler were replaced? It is typically recommended to do this around 90,000-100,000 miles.
  4. Feb 2, 2012 at 9:19 AM
    Arkansas Taco
    Arkansas
    According to sticker on timing cover the timing belt and idler were replaced by Toyota dealership 82,000 miles ago.
  5. Feb 2, 2012 at 11:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok.....Im thinking it could be a few things. Coils might be a good place to start. Afterr that, reset the code, and see what comes back.
  6. Feb 6, 2012 at 8:45 AM
    Deltabox
    Deltabox himmie's Other Half
    Nathan
    AZ-WI
    04 4runner 4wd
    Any word on this?
    If you did a compression test, a cylinder leak down test is another good idea. If you have the capability.
