Engine Needs $2,000 In Repairs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06BLUEDBLSPORT, Jan 14, 2011.
  1. Jan 14, 2011 at 8:00 PM
    06BLUEDBLSPORT
    06BLUEDBLSPORT [OP] Well-Known Member
    Colin
    Lubbock Texas
    12 Tundra DC SR5 4x4 5.7L
    True Dual Flowmaster 40 Series exhaust, Volant CAI, HIDs, Raptor series Side Steps, Weathertech Floorliners, OME 613 Shocks and Coils with Diff Drop, Rear Bilstein 5100 Shocks, ToyTec AAL, Fearless Fabrication Front Bumper
    Went to the dealership thursday for my 45K maintenance and I was told that my valve chain cover is leaking oil pretty bad. They showed me where it was and its just put alot of grease and grime around the alternator and the area surrounding it. So i was told it is approximately 2000 dollars to repair. Buuuut the good news is that its covered under warranty thank God. I asked if this is a common problem for the 4.0 V6's and was told it sometimes happens but is mostly rare. also i was told if this wasnt taken care of eventually i will lose my engine. I will post up a picture tomorrow of the leak, and i just wanted to warn yall so you guys dont lose you engine
  2. Jan 14, 2011 at 8:05 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I believe there is a TSB out for this.
  3. Jan 14, 2011 at 8:14 PM
    06BLUEDBLSPORT
    Colin
    Lubbock Texas
    I asked but the guy said no it just happens but can be covered under warranty, i guess theres a 60K mile warranty on the powertrain
  4. Jan 14, 2011 at 8:40 PM
    kbenoit001
    kbenoit001 Active Member
    Baton Rouge, LA
    09 TRD, 4x4 Sport
    3 Inch Toytec Lift, Real AAL, Wheels and tires. Working on more
    You mean the timing chain cover?
  5. Jan 14, 2011 at 8:43 PM
    wired_af
    wired_af Well-Known Member
    Alex
    Colorado Springs, CO
    '07 DC TRD Sport S/C
    There is a timing chain cover TSB for a leak. I had mine done.
  6. Jan 14, 2011 at 8:45 PM
    kbenoit001
    Baton Rouge, LA
    09 TRD, 4x4 Sport
    Yeah, I was gonna say that. Was just making sure he wasn't talking about the valve cover itself.
  7. Jan 14, 2011 at 9:14 PM
    06BLUEDBLSPORT
    Colin
    Lubbock Texas
    I think so. i forgot exactly what he told me
    Really? did they alert you of it or did you find out that it was leaking by yourself
    It might be the valve cover, im not sure, my truck goes in monday so ill get the exact info on it and let yall know
  8. Jan 14, 2011 at 9:16 PM
    Bodete
    Bodete Well-Known Member
    Missouri
    2009 SR5 DC LB 4x4
    Eibach springs w/ 5100 Bilstein shocks set to "0", Rear TSB
    My timing chain cover started leaking by the power steering pump at 19,000 miles. I got it fixed under warranty.
  9. Jan 14, 2011 at 9:19 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Sorry to hear your truck needs repair. Can you take a few pictures of where it's leaking?
  10. Jan 14, 2011 at 9:22 PM
    kbenoit001
    Baton Rouge, LA
    09 TRD, 4x4 Sport
    I would suggest to the OP that if he is talking about the timing chain cover, make sure they go ahead and change the timing chain, camshaft and crankshaft seals while they are in there. Not sure if they are including that in the service but those parts are a nominal cost and are very little extra labor to change. They certainly are not due for service yet but they will be at 100k, might as well do it now while they are in there. It will save another, out of warranty bill at 100k.
  11. Jan 14, 2011 at 9:30 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    I had a crankshaft seal go bad and had an oil leak. That sucked.
  12. Jan 14, 2011 at 9:32 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    pheewwwwwww...I'm glad its under warranty for ya bud :woot:
  13. Jan 14, 2011 at 10:15 PM
    06BLUEDBLSPORT
    Colin
    Lubbock Texas
    Thanks yall for the info, i will take pictures and ask the dealer about the other things that could be replaced while they are working on my trucks engine.
  14. Jan 14, 2011 at 10:17 PM
    06BLUEDBLSPORT
    Colin
    Lubbock Texas
    that does suck man was it under warranty?
    Me too! When i heard the cost i almost shit a brick then he said it was covered, big ass relief
  15. Jan 14, 2011 at 10:20 PM
    Khaos
    Khaos Big Member
    Bryant
    I wish. It happened at 69K I think. The service manager at my Toyota dealer is somewhat of a family friend so he got me a decent discount on getting it all fixed, still sucked though. They found it while I was getting my brakes done. That was an expensive day.
  16. Jan 14, 2011 at 10:22 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    its easy to replace it and its good to have it done atleast every 70K so when somebody drives through water none gets inside the engine
    x2 but not timing chain only guides and al lthe seals including O-rings on oil pump. And O ring on pickup line under the oil pan
  17. Jan 14, 2011 at 10:24 PM
    06BLUEDBLSPORT
    Colin
    Lubbock Texas
    Shooot, i should see if theres a warranty or tsb for that incase that might happen
  18. Jan 14, 2011 at 10:24 PM
    Khaos
    Khaos Big Member
    Bryant
    Looks like I had it done right on time then, LOL.
    That and having my u-joints go bad is the only real problem I've had with my Taco (aside from the temp gauge). Honestly, when I was younger I beat the shit out of my truck and its handled it like a tank.
    Now that I think about it, u-joints where probably trashed by me. Parking lot at my high school was a dirt lot that would flood every time it rained. I couldn't tell you how many times there where parts flooded that came up to my fog lights in depth. U joints don't like nasty water.
  19. Jan 15, 2011 at 3:10 AM
    Nightfury
    Nightfury Well-Known Member
    Evan
    Bismarck, North Dakota
    Factory running boards, Toyota (DeeZee built) toolbox, Code Alarm 5152 remote starter, Bronze TRD rims, more to come....
    Timing belts are a 90k service, and most dealers replace crank/cam oil seals when they have the front half of the motor torn apart. Timing chains are lifetime of the vehicle. Well, per Toyota repair manuals, anyway.
  20. Jan 15, 2011 at 3:16 AM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    Toyota of Plano?
