Engine Noise? Help please
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Marc529, Sep 20, 2017.
  1. Sep 20, 2017 at 7:57 AM
    Marc529
    Marc529 [OP] Well-Known Member
    This noise is not new but has anyone figured out what causes it?
    Observations:
    Happens at several different speeds.
    Happens at a point where you are decreasing throttle almost feathering after acceleration.
    There is no point where you can make sound continuously.
    Happens usually between 3rd and 4th gear but have heard it between 2nd and 3rd
    Does not sound like the rear diff noise.
    One person said it is 1320 hz wondered if it is resonant frequency associated with heat shields.
    Will not occur while not moving.
    Reminds me of sound made by passing air over a glass tube
    Don't think is is the A-arm holes since it is engine dependent
    My guess; a venturi sound in the carburetor and has to do with the valve timing changing at the point the engine load diminishes.
    Here is what it sounds like.
    https://youtu.be/mV76JHlTVl4
  2. Sep 20, 2017 at 8:08 AM
    DPT852
    DPT852 Well-Known Member
    Dan
    Connecticut
    2017 BR TRDOR
    Pretty sure that's the air conditioner. Try turning it off and driving. Mine does the same thing.
  3. Sep 20, 2017 at 8:11 AM
    Marc529
    Are you thinking it is the compressor? If that is true it could be demonstrated without driving. Having the AC off would change the engine load.
  4. Sep 20, 2017 at 8:25 AM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    OP Do you have an aftermarket intake? My GTI used to have a harmonic on the intake tube at a certain RPM.
  5. Sep 20, 2017 at 8:34 AM
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    It's definitely the AC compressor.
  6. Sep 20, 2017 at 8:35 AM
    CoastieMike88
    CoastieMike88 Well-Known Member
    Oregon
    2017 QS TRD Sport
    6" Pro Comp lift, 35's, TRD Pro grille, LED conversion
    I have that happen on mine all the time but have never been able to catch it on video!
  7. Sep 20, 2017 at 8:37 AM
    Marc529
    Stock intake.
  8. Sep 20, 2017 at 1:24 PM
    Freetime
    Freetime Well-Known Member
    2016 TRD OR AC 4x4 Quicksand
    also saying it's the AC compressor. I can almost always make mine do it on command in the morning when I turn on the AC at the end of my road.
