Engine Noise - Troubleshooting
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kthompson, Jul 30, 2021.
  1. Jul 30, 2021 at 8:38 AM
    kthompson
    kthompson [OP] Member
    2021 TRD OFFROAD DCLB
    2021 TRD OffRoad ~10k Miles
    Started up this morning just fine, but within a few seconds of running a tinging/chiming noise started. I restarted and it went away.
    Any thoughts on what this could be?
    Searched TW and didn't find any similar noise complaints, but I may have missed a post, so by all means let me know otherwise.
  2. Jul 30, 2021 at 8:52 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Sounds like an idler bearing or belt chirp imo.
    Junkhead, 9th and zoo truck like this.
  3. Jul 30, 2021 at 9:05 AM
    DeeKay20
    DeeKay20 Well-Known Member
    Danny
    Columbia MO
    2020 Tacoma DCSB TRD OR 6MT
    Dobinsons 2" lift, 33s....other stuff
    First step in troubleshooting would be to narrow down where the sound is coming from.
  4. Jul 30, 2021 at 10:32 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Serpentine belt noise would be my fist guess. Should be in warranty if you bring back to the dealer.
    Junkhead and shakerhood like this.
  5. Jul 30, 2021 at 10:38 AM
    Murd3rd
    Murd3rd I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    It's a 2021 with 10k miles on it. First step to troubleshooting would be to drop it off at the dealer where they pay for it all under the warranty.
    I somewhat remember seeing a TSB about chirping on the NHTSA website as well. Don't drive yourself crazy thinking about something that should be fixed for free whether it's just warranty work or a TSB...
    Kev250R likes this.
  6. Jul 31, 2021 at 10:53 AM
    kthompson
    Thanks all, it's definitely going into the Toyota Dealer. Just wanted to see if anyone had any insight ahead of time.
    Noise hasn't came back since.
  7. Jul 31, 2021 at 11:33 AM
    zoo truck
    None
    Sometimes moisture or water gets on the belt when first thing in the morning when its cooler...result is the belt can chirp till the engine warms enough. If its there all the time, belt likely needs to be replaced. Could be the result of a misalignment issue.
    kthompson[QUOTED][OP] likes this.
  8. Jul 31, 2021 at 11:42 AM
    soggyBottom
    soggyBottom Well-Known Member
    Vacuum hose in your ear can help find where the noise is coming from. This normally works well for hearing hissing from vacuum leaks but in your case I think it'll also work.
    With one end in your ear, move the other end around until you find the noise. Also the dealer should find and fix it.
    kthompson[OP] likes this.
  9. Jul 31, 2021 at 4:26 PM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    I got the TSB done for that belt chirp. They installed the v-rib belt and it went away.
