Engine noise when using audio and cigarette outlet
Discussion in 'Audio & Video' started by 5 Lug Fury, Oct 20, 2016.
  1. Oct 20, 2016 at 2:00 PM
    5 Lug Fury
    5 Lug Fury [OP] Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    When I use my aux cable for my radio along side with having my phone charging I can hear engine noise through the speakers. I have a stock radio modified to run the aux through the cd player.
    Now before you start saying it's probably because I modified the radio I also get engine noise through my cb radio that receives power through the cigarette outlet as well and it's a brand new cb radio.
    Im thinking the outlets need a better ground to solve the problem and before I rip apart my center console I wanted to know what you guys think. Also for what its worth I am electrically inclined.
  2. Oct 25, 2016 at 9:02 PM
    TRM
    TRM Well-Known Member
    Tyler
    Knoxville, TN
    15 DCSB TRD Sport 4x4
    I doubt its the ground, but rather poor shielding on the wires. You have signal cables next to power cables and its most likely putting out interference. Easiest fix would be try and move your power cable away from signal wire, or buy some shielded wire.
  3. Oct 25, 2016 at 9:04 PM
    Aw9d
    Aw9d That one guy
    What aftermarket audio equipment do you have?
  4. Oct 25, 2016 at 10:42 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    only a pioneer amp and a 10" kicker but those wires are separated and shielded.
    How can my cb radio have poor shielding if the radio sits in my lap and the coax cable goes out the back?
  5. Oct 26, 2016 at 5:55 AM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    This would be my guess as well
  6. Oct 26, 2016 at 7:38 AM
    Aw9d
    Aw9d That one guy
    Doesn't matter of they are wired separate it all runs off of one electrical system.
    Check all your grounds.
    If you are tapping power from another source, don't. Get a relay and use that.
    And and said, check all your grounds. Typically feedback is from bad grounding
  7. Oct 26, 2016 at 7:46 AM
    medjah
    medjah Volleyballing
    Blake
    Austin, TX
    09 Barcelona Red DCSB SR5 TRD OR
    OME 887 Springs OME 90000 Shocks OME Dakar Light Duty Leafs Wheelers SuperBump Bumpstops w/ u-bolt flip Sway Bar relocate Red Brake Lines Ultimate Headlight Upgrade Airflow Snorkel Rear diff breather mod CMC AtTheHelm Bed Stiffeners AtTheHelm Front Rail Chock System Hood Struts
    I have the JBL system in my 2009 and I get awful static when listening to the radio and charging anything. :annoyed:
    I end up using the aux whenever I have to charge my phone.
  8. Oct 26, 2016 at 7:52 AM
    Clearwater Bill
    Billy
    Largo Florida
    In the old days 'interference' was a sign of plug wires that needed replacement.
    Not saying that's it, but have the wires have been in service beyond their recommended duty cycle?
  9. Oct 26, 2016 at 7:57 AM
    Krogen
    Krogen Well-Known Member
    Puget Sound
    14 AC V6 6sp 4x4 Off-Road
    Does the interference change as you move the cable around? If so, that's a radiated interference. Also, two easy things to do are clean your battery terminals and ensure your battery to frame ground path is clean and tight. Do the easy stuff before ripping apart the truck. How old is your battery? They provide some filtering for noise and if on their last legs, may give you grief.
