Engine noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by milorsm1, Nov 15, 2011.
  1. Nov 15, 2011 at 12:55 PM
    milorsm1
    milorsm1 [OP] Active Member
    Robby
    Louisiana
    01 SR5 4x4 TRD
    Just upgraded to bilstein 5100s front and back
    Getting a ticking noise from the engine right now anyone know what that could be? This is my first Taco.
  2. Nov 15, 2011 at 12:58 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    We need a lot more info to help you out:
    What motor do you have?
    Mileage?
    Does it do it cold or hot or on startup?
    At idle only, or at speed?
    Can you be more specific about the location of the tick?
  3. Nov 15, 2011 at 1:11 PM
    milorsm1
    Robby
    Louisiana
    01 SR5 4x4 TRD
    I have the 3.4 v-6 with 113,000 miles on it. Sounds like it coming from the front. And its a faster tick when reved up.
  4. Nov 18, 2011 at 7:05 PM
    Jvajda
    Jvajda Member
    York, PA
    01 Tacoma TRD DC 4WD
    Current Modifications Exterior: aFe Stage II intake, Gibson cat back exhaust, Eagle 197 18" wheels, Toyo Open Country AT 32" tires, Bilstein adjustable 5100 (front), 5100 (rear), OME 881 springs, Wheeler's 5 leaf pack, Wheeler's braided SS brake lines, EBC Sports Roters and Green 7000 brake pads, Westin bull bar, PIAA ATP 520 lights. Sound: Kenwood KDC-994 head unit, Kenwood KAC 9105D Amplifier, Eclipse EA4200 Amp, RF P2 10" subs (x2) in custom enclosure, KFC-X1730P separates, and Boston Acoustics SC85 (rears).
    I have the same tick (same engine, 140,000 miles) and it sounds like metal on metal. It's all the time, but easiest to hear idling. I've never changed the timing belt... Maybe that could be it. I checked the spark plugs to make sure the pistons were not hitting them too.
  5. Nov 18, 2011 at 7:25 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    It is a common noise if it is the one I'm thinking about. Mine does it and it is annoying. I've read on here that is has something to do with the emission control aperatus on the 3.4L but I think they all do it for the later 1st gen model years.
  6. Nov 18, 2011 at 7:31 PM
    x2468
    x2468 Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    Did you check your oil level?
    When do these motors need valve clearance adjustments?
  7. Nov 18, 2011 at 7:59 PM
    Jvajda
    Jvajda Member
    York, PA
    Oil level on mine is good, and the engine doesn't burn any oil. I never had to add a drop between oil changes. I have to take it in for it's annual inspection anyway so I'll see what they say and let you guys know what I find out in about two weeks.
