Engine Noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roteck, Mar 3, 2024.
  1. Mar 3, 2024 at 2:55 PM
    Roteck
    Roteck [OP] New Member
    2009 Toyota Tacoma
    Hey all, new to the forum thanks to my Tacoma making some noise and I don't want to start replacing things trying to find it so hopefully someone here has experienced the same noise. My Tacoma has 278,000 miles on it and has developed two noises that I can't put my finger on. There's a sound that I can only think to describe as the sound of a supercharger haha I wish, but that's what it sounds like. It happens any time I hit the throttle and then abrubtly goes away after a certain amount of throttle and only does this when the engine is cold. I have absolutely no idea what it is and I can get a video with that sound too if no one knows what I'm talking about. There's another sound that I'm thinking is the belt tensioner but I'm not sure. It also only does it when it's cold and slowly fades away as the engine warms up. I've uploaded the sound I believe to be the belt tensioner to YouTube to post it here:
    https://youtu.be/WHIROriI0p8?si=zPrb64pePMq_9V8S
    Please let me know if you have any experience with what these two sounds are. Thanks.
  2. Mar 3, 2024 at 3:52 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    The noise in the video sounds like it could be an idler pulley. You can pop the belt off and spin them to see if they're rattly.
    kidthatsirish likes this.
  3. Mar 3, 2024 at 4:38 PM
    Roteck
    2009 Toyota Tacoma
    Okay thanks, I'll try that. I'll also see if I can get a video of the supercharger sound in the morning.
  4. Mar 4, 2024 at 8:38 AM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Yup....with that many miles of you have not started replacing things on the accessory drive you will likely have to start doing so in the near future.
    Idler pulleys are easy. Check your tensioner but those usually don't fail (but the pulley bearing will). Alternator, water pump, power steering.
    Try putting your AC on and off to see if it goes away that could help narrow it down.
