Engine Obd scanner recommendation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by C4vettrn, Jan 9, 2022.
  1. Jan 9, 2022 at 2:52 PM
    C4vettrn
    C4vettrn [OP] Well-Known Member
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    I have a 2020 tacoma and wife drives 2021 Rav4. Looking for a scanner to check codes and live data. I'm getting ready to do all my fluids at 30k and first thing I will use it for would be tranny fluid temp. I prefer a hand held wired over the Bluetooth phone app. Free upgrades would be nice and no subscription costs. Mainly Toyota use but ability to use on domestics would be a plus. Looking in the $200-$250 price range max. What y'all using and pros/cons etc.
  2. Jan 9, 2022 at 3:54 PM
    eurowner
    eurowner Duke Sky
    Scoty
  3. Jan 9, 2022 at 4:27 PM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    Following... I'm going to need one to read A/T pan temp in my Highlander...
    IcePlant likes this.
  4. Jan 9, 2022 at 4:30 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
  5. Jan 9, 2022 at 5:06 PM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    The cheapest one you can find that will bleed ABS and reads trans temp. I have the Innova 3160RS. There's plenty of others out there that meet that criteria, it just happened to be on sale when I was shopping.
  6. Jan 9, 2022 at 5:24 PM
    jaro
    jaro Member
    2020 TRD Off-Road DCSB Magnetic Gray
    Following this as well. I don’t have any immediate needs for one, but couldn’t decide between getting one of the cheaper <$50 models or if I should spend $200 or so.
  7. Jan 9, 2022 at 5:25 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
  8. Jan 9, 2022 at 5:36 PM
    GeorgiaTacoJM
    GeorgiaTacoJM @beardedtacoma
    Brian
    2019 TRD OR
    KD MAX Tune, Westcott Lift, Method Wheels, Nittos, RCI Bed Rack, Sumo Springs
    This fits my needs perfectly. Totally worth it.
    Mark77 likes this.
  9. Jan 9, 2022 at 10:33 PM
    SD Quicksand
    SD Quicksand Well-Known Member
    Alex
    San Diego, CA.
    2017 Tacoma TRD Off Road 4x4 Access Cab Quicksand
    I also have the Innova 3160RS. It is a great OBD2 reader and it will do what you require.
    Free upgrades and it will display your automatic transmission fluid temperature.
    I just went online and updated my software two days ago, and used it to read my transmission fluid temperature.
    Scangauge is also good, but I like the Innova 3160RS better.
    I got both instruments on Amazon.
    jdjones likes this.
  10. Jan 9, 2022 at 10:36 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    Sub’d
  11. Jan 9, 2022 at 10:37 PM
    Bluenoser009
    Bluenoser009 Well-Known Member
    Alberta
    06 Tacoma (A-cab/TRD/SR5/OFF-ROAD/6 spd)
    I recently bought a BlueDriver Bluetooth model off Amazon. Was recommended to me by a buddy, and I’m happy with my limited usage so far. App is pretty user friendly. And I don’t have to google codes like with the cheap $20 one I’ve used for years
  12. Jan 10, 2022 at 5:50 AM
    C4vettrn
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    I never realized the scangauge could read codes and reset. Going to look into these further.
    eurowner likes this.
  13. Jan 10, 2022 at 6:05 AM
    Mark77
    Mark
    Nothing yet
    I passed my Ohio ECheck 2 times w an o2 sensor code. Ha! You clear the code, get put of the car and on your way.
    Its nice to have. Only thing it wouldnt clear is the tpms.
    It also can be used to monitor speed, you can change the speedo on the scan gauge to match bigger tires. Shows all sorts of awesome information.
  14. Jan 10, 2022 at 7:23 AM
    C4vettrn
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    These are at the top of my list. The 3160g must be the newest model it's $50 more then 3160rs, not sure what that $50 gets you. iCarsoft TYT II Scanner is a top recommendation for Toyota specific features but have lots of complaints
  15. Jan 10, 2022 at 12:57 PM
    C4vettrn
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    So I ended spending a little more but it will pay for itself. I got the Innova 5610 because of the ability to have bi-directional communication i.e. I can send a sensor info and get a reply. It was only a little more then the 5510. Found one on eBay for $280
  16. Jan 11, 2022 at 10:09 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
  17. Jan 16, 2022 at 10:34 AM
    C4vettrn
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    Do I hooked it up today to get a idea how it works and it says my vehicle isn't supported for certain features i.e. trans temp being one of them. Sent them an email and hoping it's just something I can do a download for. I think this is where they get you $$ :)
  18. Jan 16, 2022 at 11:14 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    yea, most of those you gotta pay for the features
  19. Jan 2, 2023 at 6:43 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 80K miles
    FOX 2.5, Deavers, ARB, 4xInnovations
    Strongly considering picking up an Innova 5610 for my 2014 Tacoma. How much have you used your 5610 so far? Are you satisfied with it?
