Engine off. Transmission noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 007fodo, Oct 19, 2022.
  1. Oct 19, 2022 at 1:34 PM
    007fodo
    007fodo [OP] Gold Member
    Ian
    Coastal North Central CA
    4X4 V6 5AT DCSB 07
    Is it normal to get a low buzzing noise from the transmission when the engine is off, but the key is turned to ON?
    I first started hearing it when I installed nicer speakers with crossovers- they picked up the signal while they were tucked up near the drivers fusebox and the ecm(s) in the foot well areas. Moving them to the floor eliminated the noise, but I heard it faintly somehwere else. Crawling under the truck, I worked my way closer until I came to the transmission and decided it sounded loudest there. Has anyone experienced this before? Is it a sign that something is going bad in my trans? It could certainly use a service anyhow.
    If it would help I can upload a video.
    TIA
  2. Oct 19, 2022 at 1:50 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Mine is a manual but I would say probably normal, on many electronically controlled transmissions you can hear the solenoids buzzing with the key on.
    If you have no CEL, no codes, and it shifts fine I wouldn't worry about it.
  3. Oct 19, 2022 at 2:01 PM
    007fodo
    Ian
    4X4 V6 5AT DCSB 07
    Thank you. I guess I would not have been drawn to it if it weren't for my speakers amplifing the noise.
    I'm not having major issues with the trans- just noticing that when I'm stopped in D the trans/ drivtrain stays under load instead of letting the engine idle/ disconnect. Besides that the trans seems fine.
  4. Oct 19, 2022 at 5:46 PM
    NORCAL50
    NORCAL50 Active Member
    2014 Toyota Tacoma SR5 V6 4x4
    Mine buzzes too, noticed it when I did an ATF fluid and filter replacement.
    007fodo[OP] likes this.
  5. Oct 19, 2022 at 5:51 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Well, I guess I’ll have to crawl under and listen to mine. :rofl:
    I can’t say I’ve ever noticed mine making a sound, But
    I’ve never been under mine unless the engine was off and key out. Or key on and engine on.
  6. Oct 19, 2022 at 5:56 PM
    Tacoma Mike
    Southern Maine
    Normal
