Engine Oil Cap
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mquibble, Aug 21, 2021.
  1. Aug 21, 2021 at 6:51 AM
    mquibble
    mquibble [OP] Well-Known Member
    Michael
    2021 TacomaTRD Pro
    I was changing my oil the other day and I was underneath the truck when I realized I didn’t remove the engine oil cap to release some vacuum in order for it to drain quicker. So, what do I do? I asked my wife to remove it for me. She proceeds to unscrew the cap and immediately drops it. Has anyone ever tried to find that black cap in an all black engine bay?!?! I couldn’t believe how long it took me to find that sucker, lol.
    Well, its going to be some time before my wife helps me with anything to do with the truck. Apparently my disgust about her dropping the cap was obvious. Can’t believe there isn’t an option for a fluorescent colored cap or one that has a tether attached to it. I’ll probably affix a tether to it for that one time when we are out traveling and have to add a little oil and drop it to find it rolling away down a bank or something, lol. I’d prefer not to be stranded somewhere remote without a cap. Easy fix I reckon.
  2. Aug 21, 2021 at 6:57 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I dropped it in the engine bay one time, looked all over nowhere to be found. Pulled the skid plate and low and behold was laying in the bottom of the fan shroud...
    Bleep100 likes this.
  3. Aug 21, 2021 at 7:03 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Is it Friday already?
    :D
    If you ever loose your cap though, Toyota only makes 2 styles.
    Mines off a '70 something.
    :thumbsup:
  4. Aug 21, 2021 at 7:04 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Did you every drop a nut or bolt in the engine bay and quickly look under the truck and it's a oh shit moment when it's not there .
  5. Aug 21, 2021 at 7:05 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    LOL.....
    Don't ever drop a critical bolt, screw or a 10 mm socket.
    These things grow high speed legs before impacting the ground, then run to the farthest corner of the garage under the most difficult object to move while remaining just out of reach..............
    JustJon, Junkhead, MOC221_ and 4 others like this.
  6. Aug 21, 2021 at 7:08 AM
    mquibble
    Michael
    2021 TacomaTRD Pro
    Interesting. That’s where I found mine. I guess they all go to the same place, lol. Good to know!
    Delta09[QUOTED] likes this.
  7. Aug 21, 2021 at 8:00 AM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    there is a single edge razor blade lurking in my bench area in the garage. if it dropped and hit edge on, it could be anywhere. i am sure i will find in the most painful way.
  8. Aug 21, 2021 at 9:56 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    timer for a dozen roses!
    mquibble[QUOTED][OP] likes this.
  9. Aug 21, 2021 at 12:12 PM
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    I’d be interested to really see how much time it saves doing this. Not that it’s wrong, but I don’t always remove mine. Isn’t the crankcase vented? I’d be surprised if it helped drain any quicker.
  10. Aug 21, 2021 at 1:07 PM
    mquibble
    Michael
    2021 TacomaTRD Pro
    Well Dr Dirty- You are making an assumption and your assumption just might not be the reason why “I” release a bit of vacuum when I drain my oil. It has everything do with flow and the possibility of removing contaminants that otherwise might not escape during slower flows. A few seconds here or there is actually not something that interests me. Better, not quicker is what I’m shooting for.
    The hammer and Key-Rei like this.
  11. Aug 21, 2021 at 1:10 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    About the only thing you can do at this point is apologize to the wife for putting her in such a precarious situation. In her eyes anyway lol. Glad you found it at least.
  12. Aug 21, 2021 at 4:37 PM
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    Well mrquibbe, I assumed you were doing it because you said that you “removed it to release some vacuum in order for it to drain quicker.” I’m not being a dick and telling you it’s bad form, I’m legitimately asking if it really makes a difference. It may save a few seconds. I would think most contaminants would be caught by the filter, but my wife tells me I’m wrong all the time so maybe she’s right.
    Skydvrr likes this.
  13. Aug 21, 2021 at 4:42 PM
    mquibble
    Michael
    2021 TacomaTRD Pro
    Yep, you are correct. Quicker would likely be
    Yep, I see your point. My apologies. Quicker flow versus quicker time each with different goals.
  14. Aug 21, 2021 at 7:12 PM
    TRD2021SPORT
    TRD2021SPORT Well-Known Member
    2021 Tacoma TRD Sport AC
    It doesn't but all it took was for someone to post it on the internet..........................
  15. Aug 21, 2021 at 8:31 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
  16. Aug 21, 2021 at 8:36 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I would think whatever "vacuum" it needed would be compensated by the fresh air side of the pcv. Honestly, not too sure tho.
    mello03 likes this.
  17. Aug 21, 2021 at 8:45 PM
    The hammer
    What you're actually doing by opening the cap is letting atmospheric pressure (gravity) push down everything for you, nice work ;)
    And more velocity should help with that too
    Cheers!
  18. Aug 21, 2021 at 8:46 PM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    I dropped the cap on my wife's old 2006 Honda Odyssey and spent almost a hour to get it back out.
    In addition one day, I had to put a new radiator in my old 1979 chevy truck. Finishing up, warming it to full temp in the shop to check for leaks. Reach over to open the throttle linkage a bit, bump snap-on flank drive 9/16 wrench. Falls into fan, slings fork end first into the brand new radiator I could barely afford, cuts two cores open.
    Pouring coolant out, I reach under the truck and grab the wrench mad, and sling it at the wall. It just misses the metal and hits the insulation, then falls down in between the inner and outer skin of the building. So I crimped off those two cores, and to this day that wrench is in the wall there. I replaced it with a mac wrench so the set doesn't match, but every time I use that set I remember, don't be a dipwad and knock stuff off.
  19. Aug 21, 2021 at 8:54 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    get thee by a car audio stero shop
    get thee to the thrash bin where old speakers are thrown away
    grab a few 6x9s or 10 inchers
    those in microwave oven are great
    remove very powerful magnets
    stick 1 to tool box so U will have it later
    stick 1 to firewall where there ar NO devices
    get for picking up screws / bolts / need bearings
    not so much plastic & alum
  20. Aug 21, 2021 at 8:56 PM
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    Is this a legit Oem cap? This on a third gen ?
