ENGINE OIL CHANGE HELP!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by airmax233, Jan 28, 2020.
  1. Jan 29, 2020 at 4:38 AM
    hdn4space
    hdn4space Well-Known Member
    FL
    2013 Silver SR5 4x4
    FWIW When I purchased my truck brand new back in 2013, it had the YZZD1 from the factory. I ran it about 500 miles and changed the oil and filter to YZZD3.
  2. Jan 29, 2020 at 5:50 AM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    I believe you have to set it to the A trip odometer.....
  3. Jan 29, 2020 at 6:12 AM
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    This is what i did. I bought 10 on ebay for $40 so i always have the correct ones. I keep them in my garage and theyre fine
    airmax233[OP] likes this.
  4. Jan 29, 2020 at 6:20 AM
    Clearwater Bill
    Billy
    Largo Florida
    Put the new filter on. You nor the truck will know the difference.
    If you want the larger capacity filter to feel good, put one on the next scheduled change.
    Wulf and airmax233[OP] like this.
  5. Jan 29, 2020 at 6:27 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    ^This and maxing out the Mobile1 rebate (that comes out in the Spring typically) will get the cost of an oil change to $30 or less.
  6. Jan 29, 2020 at 7:19 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    This.
    And like stated grab a case of the D3 filters for the next 50k miles (10 filters at 5k OCI's)
  7. Jan 29, 2020 at 8:33 AM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    If you use an aftermarket oil filter for your application you will find that it's usually much smaller than the original D3 Toyota filter .
    I've used both on my 2013 4 Lt. no issues whatsoever, right now I'm using the Fram Ultra I believe the number is 3600 no issues whatsoever.
    TOMB
  8. Jan 29, 2020 at 9:06 AM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    I'm not sure it matters but I have used "B" on my 2015.
  9. Jan 29, 2020 at 9:46 AM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    I have to use A on my 2012.
  10. Jan 29, 2020 at 10:26 AM
    jadesparrow
    jadesparrow Well-Known Member
    Tim
    San Angelo, TX
    2011 White Tacoma 4.0 V6 4wd
    3" lift, ARB bumper
    I've had it set to the overall odometer and it cleared the maint required light just fine. I think all that matters is the turning it to start with the button pushed in and letting it clear. 2011 fwiw
  11. Jan 29, 2020 at 10:50 AM
    jtaco11
    jtaco11 Well-Known Member
    long/short filter doesn't really matter. look at aftermarkets they are mostly the shorter ones. ive use all kinds purolator/supertech/fram/proline just change regularly
  12. Jan 29, 2020 at 11:13 AM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    If it really bothers you. Go buy a D3 tomorrow and switch them. It's not worth worrying about your truck for the sack of $5. Like others have already stated. The D1 and D3 are the same except for length and corresponding capacity. The D1 is still a very good quality filter.
    l run the D3, and if it was me. I'd go buy a D3 and put it on.
    It's most likely completely unnecessary. But that's what l would do to alleviate any concerns that l had.
    Plus it's so easy to do!!!
    airmax233[OP] and jtaco11 like this.
  13. Jan 29, 2020 at 11:30 AM
    jtaco11
    then the next question will it be ok if I drain and reuse my brand new oil. lol
  14. Jan 29, 2020 at 11:33 AM
    airmax233
    airmax233 [OP] Always ready for the next adventure
    Southern California
    12 PreRunnerTrd sport R.I.P 21 Tacoma Off road 4x4
    2.5 Kings w/resi Adj. Total Chaos Upper control arms. IG: Cement_runner23
    Update guys! So for the reset on maintenance required it was on trip A for my 2012 I tried it on trip B and it didn’t work. Thank you so much everyone!
    I will end up buying a box of the correct filters!
  15. Jan 29, 2020 at 11:36 AM
    #35
    airmax233
    Southern California
    Their is no need to drain the engine oil!
    BKinzey likes this.
  16. Jan 29, 2020 at 11:42 AM
    #36
    jtaco11
  17. Jan 29, 2020 at 12:04 PM
    #37
    Rick's 2012
    Rick
    Costa Rica
    Stock
    Just swap the filters. No need to drain the oil.
  18. Jan 29, 2020 at 12:09 PM
    #38
    Rick's 2012
    Rick
    Costa Rica
    Stock
    Never reuse a filter that you've damaged. It's not worth the possible damage that could result from the restricting oil through the filter.
  19. Jan 29, 2020 at 12:21 PM
    #39
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Agreed. I’d change it for sure, but personally wouldn’t be afraid to drive the truck unless it causes a leak due to the different design.
    Rick's 2012 likes this.
  20. Jan 29, 2020 at 12:29 PM
    #40
    Rick's 2012
    Rick
    Costa Rica
    Stock
    I wouldn't be afraid to drive it either.
