engine oil drain plug for 2RZ FE
Discussion in '1st Gen. Tacomas (1995-2004)' started by grovestreet, Sep 14, 2013.
  1. Sep 14, 2013 at 1:02 PM
    grovestreet
    grovestreet [OP] Well-Known Member
    is it the one I circled below?
    Also, does the drain plug need replacement sometime now or in the future?
    Thank you!
  2. Sep 14, 2013 at 7:03 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
  3. Sep 16, 2013 at 7:19 AM
    dorman68
    dorman68 New Member
    If the threads are in good shape then there is no need to replace the drain plug.
  4. Sep 16, 2013 at 7:20 AM
    zk6760
    zk6760 Well-Known Member
    SLC, UT
    2010 Off Road
    Just got it!
    If you buy a fumoto valve you'll never have to mess with the drain plug again - simply open the valve, let oil drain, close valve. No need to take it in/out after initial install.
  5. Sep 16, 2013 at 8:39 PM
    grovestreet
    Thank you for all the replies.
    I did consider fumoto but since I only need one oil change per year (full syn and maybe 6000 miles) I think I can save the $30.
