Engine oil drain plug with Fabric washer, torque spec.
Discussion in 'Technical Chat' started by pickmeup, Jun 19, 2015.
  1. Jun 19, 2015 at 8:46 AM
    pickmeup
    pickmeup [OP] New Member
    Eric
    2011 White Tacoma Base
    I recently bought a 2011 2.7L Standard cab. The dealer sold me an OEM oil filter (73mm cap wrench) and a Fabric washer for the oil drain plug. I've never used a fabric washer for this application (they are usually aluminum).. so I ask about the torque spec. He replied 14 Newton-meters...which is 10.3 ft-lbs. I've read that many owners are tightening this plug to 30 ft-lbs. That may be the the spec. with an Aluminum washer but not the fabric style. Also, it's not a good plan to reuse this washer, no matter what the material, as they lose their "locking" characteristic after their first "crush". If an upside-down drain plug is not tightened correctly...it can unscrew. Does anyone know when and why Toyota changed from an aluminum to a fabric plug washer?
  2. Jun 19, 2015 at 5:42 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Last one I bought in 2014 was aluminum for my 07.
  3. Jun 19, 2015 at 5:48 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    I worked for Toyota from 2004-2006 and we always used the fabric washers for engine oil.
    As for torque, I have never seen anyone use a torque wrench on an oil pan bolt. Anywhere, ever.
    30ft-lbs seems like a lot though... If I were to estimate I would say in the 10-15ft-lbs range.
  4. Jun 19, 2015 at 5:52 PM
    TacoFirefighter
    TacoFirefighter Its Me!
    Greenville NC
    2014 Taco DBL Cab 3" ToyTech Lift 305/60/18
    3" ToyTech Lift, 305/60/18 Nitto Terra Grappler Tires, 18" Fuel Kranks, LED Strobes
    The "frabic washer" in question has aluminum in the middle, if it is the same Toyota part number we use. And the torque spec is around 32ft-lbs.
