Engine oil drain plug WTF!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by maileboy, Jun 22, 2018.
  1. Jun 22, 2018 at 11:59 PM
    maileboy
    maileboy [OP] Well-Known Member
    David
    Mt. View (Big Island) but from Maili
    2017 TRD OFF-ROAD 4dr 3.5-auto, Magnetic Grey
    Well I had my 6 mo BS free service, only 2500mi but wanted to change the oil and I know, waisting money etc.....but I got couple cases of Mobile 1 from Costco cheap and the Aluminum Toyota oil filter cover so I decided to do it. Well I drained oil, plug was a little more than hand tight, then the gasket was smashed on the oil pan, couldn't come off, tried a flat screwdriver, ended up scraping it off with a razor blade! Pan surface was dinged from screwdriver so I filed it flat and put a new gasket, OEM, and finished the oil change.
    Is that how the gasket is every time? And I tried to take off the rear half of the skid plate/pan, to file the gasket surface and the damn bolts was so freaking hard thought it was going to break, so I retightend it and that was a bitch. Going to have the dealer remove the bolts at next service!
    Anyway, the oil was pretty dark, almost black, the filter was black with metal shavings between each fin! I'm glad I did the oil change, I'm doing it every 6mos, retired and don't put on that much mileage and very little off road, and it won't break the bank!
    I should have taken pics but just wanted to know if that's how the drain gasket is every time you change oil? I wonder if dealer changes the gasket when they do it!
    Thanks for letting me vent....let me know if anyone else had this gasket problem.
  2. Jun 23, 2018 at 12:04 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
  3. Jun 23, 2018 at 12:56 AM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
  4. Jun 23, 2018 at 1:01 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    [QUOTE="maileboy, post: 18100132, member: 238579" then the gasket was smashed on the oil pan, couldn't come off, .[/QUOTE]
    i changed mine a couple of weeks ago, the last time it was changed at the dealer, the 24 month free change. when i changed it same thing the washer was flattened into the metal on the pan and could not remove it. i just left it there a put on a new washer, will see how it looks the next time i change the oil. and yea, the drain plug had been over tightened and took more than the usual muscle to break loose.
    must be a hawaii thing...does your costco sell 0-10W on maui i also get at costco but is 0-20W do not think it matters no freezing winters here. aloha
  5. Jun 23, 2018 at 3:03 AM
    Rraiderr
    Rraiderr Well-Known Member
    Great White North
    2017 Tacoma TRD off road
    Working now a list
    I tried using a dab of grease and also oil but it sticks evenly time.
    I use a plastic scraper to remove it and bought a bad of gaskets from Amazon so I use a new one each time.
    tonered likes this.
  6. Jun 23, 2018 at 3:08 AM
    bv8ma
    bv8ma Well-Known Member
    Bill
    MA
    2017 TRD OR
    I don't remember this being a problem for me but now you have me wondering if I just didn't realize there was a gasket! At any rate, I put on a fumoto drain valve and it's not leaking so I'll just give it a check next change.
    over60 likes this.
  7. Jun 23, 2018 at 3:09 AM
    hotrod45
    hotrod45 Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
    gasket should not be that tough to remove. i've changed my oil several times. i suspect tech is using his little 3/8 impact to tighten the plug. yes, the skid plate is a pain.
  8. Jun 23, 2018 at 3:29 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    The color of oil is NOT indicative of the condition of the oil.
    If you put fresh oil in your truck, drove around for 20-30 miles and changed it again.... it would be black. Oil is exposed to engine combustion and will turn black from carbon.
    I have to use a flat head screw driver each time I change my oil to scrape the gasket off because it adheres pretty good. But not so bad I damage my oil pan trying to remove it.
    I'm willing to bet the dealer has not been changing your gasket when you take it to them.
    Which is why you should never take your truck to the dealer LOL even for "free" Toyota Care.
  9. Jun 23, 2018 at 4:07 AM
    vendrakk
    vendrakk Well-Known Member
    Kirk
    Ontario, Canada
    '17 DCLB TRD Sport w/Upgrade
    - Ready Lift 3" F 2.5" R - TRD Pro Grille - 275/70/R17 KO2s on TRD Pro Rims - Rigid LED Foglights - Window Tint - Bed Mat - K&N 63-9039 CAI and more to come when back home to install which include... - ACEkraut flush mount front license plate bracket - Tacowiede milled aluminum stereo knobs - Kicker speaker upgrade w/ Subaru tweeters - AVS low pro window deflectors - LED bulb conversion for interior/license plate - Husky mats
    I brought my truck in for the 6 month / 8000km change which doesn't include an oil change. I was going to pay for the oil change anyway just as the "first" one instead of waiting for the 12 month / 16,000km. But the dealership just did the Number 2 service which includes an oil change and cost me nothing .
  10. Jun 23, 2018 at 4:35 AM
    Marbleyard
    Marbleyard Thread killer
    Virginia
    2019 4Runner Pro
    SOLD 2016 taco: premium technology and tow package. OV Tune 1.05; A.R.E. V Camper Shell; BRO grille & Tails; OEM bed mat; Xenon Depot HID headlight conversion; reflective gray tailgate letter inserts; GoPro session; Hondo radio knobs; K&N cold air intake, quicksand painted dash bezels, Subaru dash speakers, Kicker CS 6x9 fronts and 6.5 rear speakers; All LED interior lights and LED high-beam headlights. Redline elite hood shock props. prinsu cab and camper rack with rough country 30" light bar; (2) 8" rear facing “F.U.”rough country black LED lights; prinsu cargo basket kit, (2) prinsu load racks; roadshower 4; ARB 2500 awning and room kit; weather tech floor mats; carhart seat covers; ckma12 ARB air compressor under the hood; blue ridge overland gear air tools bag, tool bag, driver's seat molle. Rack mounted TRED 800 recovery treds and plano case. Rotopax water and fuelpax fuel canisters; Pelican cased first aid kit in bed. rockblokz mud flaps. ARB rear dif. breather. Stand alone fuse block. SSO bumper with 10k smittybilt synthetic line winch and factor55 ultrahook. Pro Eagle 2-Ton “The Beast” jack. OME lift kit: 90000 front shocks and 886 OME coils, Camburg 310078 UCA, 60091 rear shocks with light duty Dakar leafs. Good Year duratracs 285/75R16. Black vinyl inlays on factory OR wheels; RCI Steel Front/Trans/Trans Case/Rear Diff Skids, Alum A-Arm; Mobtown bolt-on sliders with scorpion bed coating; pelfreybilt aluminum fuel tank skid; Cali-Raised full length Molle storage LH & RH bed sides; Caliraised bedside reinforcements; HELLA sharptone horns; Optima blue-top battery with AJT machined red tiedown bracket. AJT quicksand key fob. Overland Bound member #6996
    U-bolt, over60 and xxTacocaTxx like this.
  11. Jun 23, 2018 at 5:07 AM
    Xena1
    Xena1 Well-Known Member
    Ron
    2017 Tacoma Access Cab
    My guess is they never changed your oil at 2500 miles.
  12. Jun 23, 2018 at 6:03 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
  13. Jun 23, 2018 at 6:18 AM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    PackCon[QUOTED] likes this.
  14. Jun 23, 2018 at 6:31 AM
    Marbleyard
    Virginia
    2019 4Runner Pro
    I went with the F103N,no complaints the lack of mess it worth it. So used to having my hands covered in motor oil for years it’s almost doesn’t feel like an oil change any more. http://www.fumotooildrainvalve.com/f103n.html
  15. Jun 23, 2018 at 6:40 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Nothing unusual about finding a bit of metal in your filter. The difference is, with the exposed media of a cartridge filter you can actually see what's in it. It's always been there....you just couldn't see with a spin-on can filter.
    The metal wasn't floating around the engine. It was in the filter where it belongs
  16. Jun 23, 2018 at 6:48 AM
    Clearwater Bill
    Billy
    Largo Florida
    Not sure what all the obsession is about replacing gaskets at each change??
    My '04 (last new purchase) with 120k and over a dozen changes is still on the OE gasket.
    No drips, no runs, no errors.
    Now that I think about it, while I have an assortment of such gaskets on hand, I've only had to use/replace one probably 6 times over 50+ vehicles in several decades of driving/self service. And those replacements were on used cars and my first change on them. And only if the pan was wet in the plug area prior to the change.
    specter208 and kgilly like this.
  17. Jun 23, 2018 at 7:09 AM
    erics
    erics Well-Known Member
    Eric
    PA Slate Belt
    2018 Tacoma TRD Offroad 6-speed
    I’ve been wondering the same thing. I changed the drain plug and gasket ONCE on my ‘97 F150 in roughly 240k miles. Same for my wife’s ‘02 Liberty that went over 300k. Both times they were replaced only because the drain plug threads were getting a bit rough. Oil was changed in both every 5k religiously.
  18. Jun 23, 2018 at 7:39 AM
    Daver90s
    Daver90s Well-Known Member
    Hudson Valley NY
    '17 TRD Sport 4X4
    My wallet is empty
    I had the same issue when I changed the oil at 5,000 miles (so it was like that from the factory) - I ended up leaving it alone because I didn't want to wreck the pan. I assume that the dealer was able to get it off and replace it at the 10k change. Or, maybe they just leave it there as well.
  19. Jun 23, 2018 at 7:43 AM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    According to my Toyotacare guide the first oil change is at 10,000 miles. And the first scheduled service is at 5,000 miles.
    STexaslovestacos likes this.
  20. Jun 23, 2018 at 8:36 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
