Engine Oil Drain Valve (Fumoto)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kevinztaco, Mar 8, 2014.
  1. Mar 8, 2014 at 9:44 AM
    Kevinztaco
    Kevinztaco [OP] Well-Known Member
    none yet
    Hey guys....., what's your experiences with this Fumoto drain valve? I just installed mine on @15k miles schedule oil change and it looks alright but I fear that an accidental bump on something may get my engine oil pouring out. Unfounded fear?
  2. Mar 8, 2014 at 9:46 AM
    SigSense
    SigSense Well-Known Member
    13 TRD Sport DCLB 4X4
    Have had one installed for over 8 years, never a problem.
  3. Mar 8, 2014 at 9:48 AM
    mclapperton
    mclapperton Well-Known Member
    Sacramento, CA
    2019 TRD Sport
    Put a 5/8" (I think) spring clip on there. It keeps the lever in place. Google it. I've had mine for 50k so far and no issues.
  4. Mar 8, 2014 at 10:00 AM
    Kevinztaco
    none yet
    umm...I'll goole it. (update) Found it. Thanks! 5/8 Hose clip to secure the lever :locked:!
    May be this is unnecessary but I'm thinking about wrapping it with something to avoid oil, salt, and dirts from clogging it.
  5. Mar 8, 2014 at 1:35 PM
    mclapperton
    Sacramento, CA
    2019 TRD Sport
    Cool man they make oil changes a breeze. The clip's probably overkill, but it gives me peace of mind. I wouldn't worry about it getting clogged.
  6. Mar 8, 2014 at 1:58 PM
    rickcrna
    rickcrna Well-Known Member
    Rick
    Central Oregon
    '13 AC SR5 4WD I4 Auto MGM
    Have used the fumoto valve on all my vehicles for the past 10 years and have never had a problem or failure. Sure makes oil changes MUCH easier and less messy.
    My first oil change is coming up on my 2013 Taco, currently at 4900 miles and plan to install the fumoto.
  7. Mar 8, 2014 at 7:55 PM
    mcdee
    mcdee Well-Known Member
    mike
    Northern Cal
    12 PreRunner OffRoad TRD
    TRD center cap, quick bed mat, Gatekeeper, WTs, TRD skid plate from bpfab, plastidip emblems, security slider bar, interior LEDs, AFE Pro Dry air filter
    I've never had one but have considered switching at my next oil change. Curious if you plan to use the N (nipple)series or not, don't know if it makes change/access easier.
  8. Mar 8, 2014 at 7:59 PM
    WickedTaco
    WickedTaco Well-Known Member
    Aaron
    Treasure Coast, FL
    '11 Silver DC TRD OR 4x4
    iPod Interface, Bully Tailgate Lock, ScanGaugeII
    I have the one without the hose nipple and it's a good bit above the stock skid plate. Not a chance of snagging.
  9. Mar 8, 2014 at 8:43 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I was gonna buy one, but then I read that the drain valve threads too far into the pan, part of the stud protrudes up into the pan by like 3/8" or something. Because of this, it doesn't allow for all the oil to drain out.
  10. Mar 8, 2014 at 8:52 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Hmmmm. I have been going back and forth on getting one. This never dawned on me. Can anyone confirm? Wonder how much it matters too. You're always gonna have a little dirty oil mix in that's throughout the engine.
  11. Mar 8, 2014 at 9:00 PM
    WickedTaco
    Aaron
    Treasure Coast, FL
    I don't know about that, but I always get 5+ quarts drained
  12. Mar 8, 2014 at 9:13 PM
    moondeath
    Pa, Gardners
    It would be easy for someone who owns one to check. Measure the length of the threaded stud and compare it to the length of the inner pan threads.
  13. Mar 8, 2014 at 9:24 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The tiny bit of oil left in an engine using the Fumoto Valve is so negligible after it is diluted with 5+ quarts of fresh oil. There are lots of people on here that have been using them for years with no issues.
    Even with the drain plug you don't get all the dirty oil out.
  14. Mar 8, 2014 at 9:57 PM
    rickcrna
    Rick
    Central Oregon
    Over the years, I've had the valves with the nipple and without and most of the time I haven't bothered to attach a hose to the nipple. I just open the valve and let the oil drain into pan until it stops.
    I would never go back to dealing with loosening and tightening the oil drain plug again. Not sure why so many people "overthink" these fumoto valves but to each their own I guess.
  15. Mar 9, 2014 at 4:03 AM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    ^^this^^
  16. Mar 9, 2014 at 5:18 AM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    I've had one on my 99 for a few years now. I love it. Only complaint is that the oil drams pretty slow. Oh well. I will be changing my oil pan within the next couple months. When I have the pan off I will see how much the fumoto protrudes into the pan.
    These things make changing oil with aftermarket skid plates a breeze.
    I can't imagine all the suckers removing 50+ pound skid plates every time they do an oil change. I have a hose on my "nipple" model valve and run it through the IFS skid drain hole.
  17. Mar 9, 2014 at 5:54 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    I do a lot of off-roading and I have never had a problem. The valve is up under the skid so nothing can hit it.
    The oil does drain slow so I always make sure the engine is hot so the oil is thinner and comes out faster.
  18. Mar 9, 2014 at 5:57 AM
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Got a open style on the wall,,still in the bag.
    Pops had one on his Cessna Lycoming 230HP. The Lycoming drain valve was $110. Fumoto was $35 at that time. Same part minus the small FAA certified hole($$) drilled in the lever to saftey wire it closed.
  19. Mar 9, 2014 at 6:28 AM
    zonian
    zonian Well-Known Member
    Paul
    Knee Deep in the Hoopla.
    2012 TRD Sport 4X4 - Pyrite Mica
    Raptor 4" Black Oval Nerf Bars, Hard-Wired Uniden RD9XL Radar Detector, Anytime Fog Light Mod, 12V Power outlet in Bed, Tailgate Anti-theft Mod, Distinct Offroad lightbar, 2 Hella Micro FF Driving Lights, 2 Hella Micro FF Fog Lights, Rear Slider Window Opener
    I installed one (nipple type) at my 30K oil change...now approaching 50K, no issues. Agree with the others that the oil drains really slow...but it makes oil changes so damn easy. I also used a bonded seal, instead of the washer that comes with the valve...no leaks.
    Paul
  20. Mar 9, 2014 at 6:56 AM
    moondeath
    Pa, Gardners
    This is probably true, but it would just bother me. I'm the type that once I pull the plug I let it drain for at least 30 minutes or until no more drips out. Just knowing that there would be an unnecessary puddle on the bottom of the pan every time I changed my oil would drive me crazy. Thats just me though.
