Engine oil everywhere
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vinchez78, Nov 20, 2023.
  1. Dec 7, 2023 at 4:01 PM
    #41
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [TO] V6 Tow Package [ED] Entune Audio Plus
    99% Stock: OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer). TRD Pro Grille insert, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    Do a normal oil and filter change in your driveway or trusted garage and see what happens. Put in the right amount of oil, remove the old oil filter and inspect the gasket, put a little oil on the new OEM filter and tighten it down by hand to the spec on the package. Clean up any oil in the area and start it up. Check the area for leaks. I'm thinking the oil filter was not quite tight and over time made a big mess out of a little one. You should know in less than 30 seconds if this was the cause. Good luck! :proposetoast:
  2. Dec 7, 2023 at 7:36 PM
    #42
    Vinchez78
    Vinchez78 [OP] Well-Known Member
    Alvin
    Black Taco TRD sport
    I ordered a new housing and gaskets after an initial inspection at the Toyota dealer will have it completely inspected this weekend when I bring it to them on Saturday and if all it needs are the gaskets and not the housing I'll just pay a restock fee, just haven't had time due to my busy work schedule to do the inspections myself
  3. Dec 7, 2023 at 7:36 PM
    #43
    Vinchez78
    Alvin
    I actually replaced it with a new one and still leaking
  4. Dec 9, 2023 at 8:44 PM
    #44
    WOODY2
    WOODY2 Well-Known Member
    RAMONA,CA.
    Did you check to see if housing threads are buggered up?
