Engine oil fill spout on truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by aaen, Aug 11, 2017.
  1. Oct 6, 2020 at 8:55 PM
    #61
    CoWj
    CoWj Lost and Found at the same time.
    Wyatt
    Northern CO
    Burt: 1998 2.7 Regular 5 speed 4x4
    Bilstein 5100, ARB Bumper, Warn VR EVO 8, 34x10.50 Toyo 4.88s ARB Locker
    We are aware that these fill necks are rather weak and when they come in contact with anything, battery and/or otherwise they tend to break off. So we found a Toyota OEM Part (#12185-38011) That is a direct fit and will resolve all issues of contact and weakness of the oil fill neck. With Oil seal (#12196-38010) This fits the factory studs and still allows for full use of the oil fill neck and retains use of the factory Filler Cap.
  2. Oct 6, 2020 at 9:03 PM
    #62
    Bishop84
    Bishop84 Well-Known Member
    I think 2nd gen guys used to buy the tundra neck for the super charged models, wonder if it fits the 2gr.
  3. Oct 7, 2020 at 3:51 AM
    #63
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    Anything about the weight of the recommended batteries? I have 2x pc1400s and I'm worried now that the wheel well is going to start cracking
    DAS Taco likes this.
  4. Oct 7, 2020 at 6:19 AM
    #64
    CoWj
    Wyatt
    Northern CO
    Those are the recommended batteries for the side by side system, as the instructions mention, for optimum strength, use of all 4 rivnuts is recommended calling with using the M6 bolts, washers, and nuts in the other holes will also provide maximum strength. Making sure than the tray is bolted down tightly will also reduce the amount of street placed on the fender. So checking the bolts every few months is recommended to reduce metal fatigue.
    That being said, we haven't seen many issues with this on either the 2nd or 3rd gen models. Not to say it doesn't happen, we just haven't had many trucks roll through the shop with cracks forming. If all the bolts holding the tray are tight and it has no movement it while reduce the likely hood of a crack starting.
    b3itz[QUOTED] likes this.
  5. Oct 7, 2020 at 7:20 AM
    #65
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Good stuff - thanks!!
    CoWj[QUOTED] likes this.
  6. Dec 8, 2020 at 8:50 AM
    #66
    OBXRon21
    OBXRon21 New Member
  7. Dec 8, 2020 at 8:51 AM
    #67
    OBXRon21
    OBXRon21 New Member
    How did your jb weld repair hold up over time? The dealer is telling me to replace my valve cover gasket cause it’s still leaking oil but it sounds like a load of crap to me. Instead of paying almost 900 dollars for them to replace it I think I’m gonna go back and give another shot at gluing it back on
  8. Dec 8, 2020 at 10:40 AM
    #68
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Side to side in a longitudinal mounted engine and front to back in a horizontally mounted engine. Have someone rev the engine in your truck and see which way it moves. It moves because the crank is accelerating in one direction and the engine block in the other..... and because it uses soft mounts to absorb some of the vibration.
    TartanEagle likes this.
  9. Dec 8, 2020 at 10:44 AM
    #69
    Woodrow F Call
    Colorful Colorado
    Why? It does a fine job when in the application it was designed for.
    DAS Taco and Skydvrr like this.
  10. Dec 8, 2020 at 10:47 AM
    #70
    Woodrow F Call
    Colorful Colorado
    Applied correctly, epoxy can do a great job. I'd imagine it was more of application than design, otherwise we'd have tons of them falling off.
  11. Dec 8, 2020 at 4:23 PM
    #71
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Well considering the comment was 2 years ago, I had to review the thread and what I was talking about.
    I was talking about the factory design of how the neck is attached to the valve cover. On a lot of vehicles with a neck that long it threads into the valve covers at the bottom a quarter turn. So you can actually remove that piece when doing work or replace it if it was cracked or or something.
  12. Dec 8, 2020 at 7:46 PM
    #72
    RisingWithoutWings
    RisingWithoutWings Well-Known Member
    SoCal
    2016 Tacoma TRD Off-Road
    Jb weld is still holding up good after a few years now. I used the high heat putty. Make sure you let it cure. I think the first time I didn't let it cure and it only last a few weeks before it fell off. The second time I let it cure for a day or two and it's been solid ever since.
    This is what I used
    https://www.jbweld.com/product/highheat-epoxy-putty
  13. Dec 8, 2020 at 7:58 PM
    #73
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
  14. Dec 11, 2020 at 8:28 PM
    #74
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Epoxies generally work better on scuffed surfaces than smooth ones too.
  15. Dec 11, 2020 at 9:26 PM
    #75
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    How does this resolve the issue of the weakness with the oil fill neck? Looks like it just replaces the long, upper part with a short, upper part, but the adhesive joint at the valve cover still exists. Isn't that just a Lexus part sans the baffle? Maybe I am missing something?
  16. Dec 12, 2020 at 7:20 AM
    #76
    CoWj
    Wyatt
    Northern CO
    What it does it reduce the chance of being hit. While it doesn't fix the weakness in Toyota's design, it does reduce the ability to break it off at that weak point. Reducing the chances of damage.
  17. Dec 12, 2020 at 8:12 AM
    #77
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Loctite makes structural adhesive with primers etc. If mine failed that's the way I'd go
    shakerhood likes this.
  18. Dec 12, 2020 at 8:39 AM
    #78
    GrundleJuice
    Michigan
    2016 TRD Bro
    Ahh, got ya. I thought you meant it made it stronger, since you said it "resolved issues of weakness". It would be nice to find a actual fix to the problem instead of trading one potentially big inconvenience for a regular smaller inconvenience.
  19. Dec 12, 2020 at 8:53 AM
    #79
    GrundleJuice
    Michigan
    2016 TRD Bro
    The loctite H4800 is probably the best solution for this type of joint. The primer/catalyst stuff will not work well without perfectly clean/smooth surface and in my experience with it, impact resistance is just ok and peel strength is lacking. I have never used any that was compatible with plastics, though. The H4800 is some seriously tough stuff, not brittle or super rigid, and designed for plastics/composites.
    Edit: H4800 working temp range may be a bit narrow for this application. The tech specs chart states 77-180F, which I am pretty sure is not correct. The min working temp has to be lower than 77F. Loctite TDS won't download, so I can not verify.
  20. Dec 12, 2020 at 8:54 AM
    #80
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    W/O replacing the valve cover with a heavier duty piece, there really isn't much that can be done... maybe a support bracket. Easier to simply swap in the shorty and pick up one of the various funnels that screw into the Toyota oil fill cap location. A funnel is how it should be filled, sure it's fun and rewarding to pour a whole 5 quart container into that little hole w/o spilling, but I have better things to do.
