Engine Oil Smoke Please Help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacomalex1949, Sep 15, 2022.
  1. Sep 15, 2022 at 3:31 PM
    tacomalex1949
    tacomalex1949 [OP] Well-Known Member
    Alex
    2021 Tacoma DCSB
    So I was filling oil today and my hand bumped and I spilled oil on the engine (area around the oil reservoir).
    wiped up a bit and sprayed engine degreaser and gave it a spray with the hose. Let it air dry for like an hour in my driveway.
    Went to start it and immediately got light smoke coming from exhaust manifold area, I assumed it might be some oil burning on the hot parts.
    Maybe it was just water evaporating? I shut the engine off right away and tried again 30 minutes later, same deal.
    It’s just sitting in my driveway, any ideas what to do? Should I just hit it with degreaser and the hose again? The smoke is coming from under the heat around the manifold so it might be tough to clean that out.
    I know I’m a dumbass and it’s not even Friday! Trying to tell myself just to relax.
    2021 SR5 just for the record.
    hiPSI likes this.
  2. Sep 15, 2022 at 3:36 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Just drive it, it will burn off.
  3. Sep 15, 2022 at 3:42 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    We’ve all done it, burn it off. Whatever doesn’t burn off will prevent rust for months to come.
  4. Sep 15, 2022 at 3:45 PM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    +1 on the burnoff. Been their done that when I was younger and actually changed my own oil. Admittedly that was in the days of round air filters and changing points, but still....:anonymous:
    Rock Lobster likes this.
  5. Sep 15, 2022 at 3:45 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
  6. Sep 15, 2022 at 3:49 PM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Brake cleaner on cold engine just douche it. It will down down and it dries instantly . Get Walmarts brand, it'll save you some coin. And in the future , when you do your next oil change, use it to get the residual off the pan etc.
  7. Sep 15, 2022 at 4:04 PM
    tacomalex1949
    Alex
    2021 Tacoma DCSB
    Should I be worried about brake cleaner near the rubber and plastic? I know the oil filter is plastic too.
  8. Sep 15, 2022 at 4:07 PM
    AM6217
    I use the Walmart one , and non chlorinated brake cleaner for auto zone also.Which ever I can get my hands on. I wouldn't worry about too much.
  9. Sep 15, 2022 at 4:08 PM
    saint277
    saint277 Vigilo Confido
    Obligatory "partout when?" joke.
    wilcam47 and whatstcp like this.
  10. Sep 15, 2022 at 4:08 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    pull the engine...complete teardown and degrease...
    Nawwww man... let that shit smoke off. You'll be just fine.
  11. Sep 15, 2022 at 4:09 PM
    AM6217
    Brings back memories of gunking the engine and hosing it off. Thing would smell like shit for a week after.
    Captqc and shakerhood like this.
  12. Sep 15, 2022 at 4:28 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  13. Sep 17, 2022 at 9:06 AM
    tacomalex1949
    Alex
    2021 Tacoma DCSB
    My nervous ass degreased the whole engine bay this morning….smoke gone. Thanks for the help everybody. We made it past Friday.
  14. Sep 17, 2022 at 10:22 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I once had our cat knock over a qt of oil over the engine when i was doing an oil change on the tundra. I just took the garden hose, and sprayed it away best as possible. I looked at it this way...i had some rust protection. Any remaining oil flim will just smoke and burn away.
    Chew likes this.
  15. Sep 19, 2022 at 4:05 PM
    Eli0841
    Eli0841 Well-Known Member
    Elias
    2019 Cement Tacoma TRD Off Road
    At long as it’s not a huge smoke ball it should be normal. But if I was you I would be posting the same question so I see where your concern is
  16. Sep 19, 2022 at 4:17 PM
    tacomalex1949
    Alex
    2021 Tacoma DCSB
    In all honesty this might be the most respectful reply I’ve ever seen on TacomaWorld. I appreciate it
  17. Sep 19, 2022 at 4:25 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Oil on a hot exhaust manifold always puts on a show! And few (that change their own oil) can say this has never happened to them! Don't sweat it, it'll burn off.
    wilcam47 and GarrettTacoma like this.
