Engine oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bra, Mar 16, 2014.
  1. Mar 16, 2014 at 1:27 PM
    bra
    bra [OP] Well-Known Member
    2008 AC 4X4 TRD sport
    Badges off
    The country where I live got temperature that never goes under 20 degrees Celsius but can go to 35 degrees Celsius. Should I use Mobil 1 5w40 or 5w30?
  2. Mar 16, 2014 at 1:28 PM
    bra
    Badges off
    I live in a country where temperature never goes under 15 degrees Celsius and I always used 5w30 synthetic oil. Should I continue to use that or should I use 5w40 now?
    Also for the air filter, someone said it is better to use original paper one. I just bought and installed a TRD air Filter that is cleanable and could be last the life of vehicle, is it better I switch back to a paper one to protect my engine?
  3. Mar 16, 2014 at 1:29 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    5w 30 is fine.
    I would just use paper element for the air intake.
  4. Mar 16, 2014 at 1:37 PM
    bra
    Badges off
    Is it possible to clean the older one air filter like cleaning the AC filter?
  5. Mar 16, 2014 at 1:37 PM
    bra
    Badges off
    AC = air conditioner
  6. Mar 16, 2014 at 1:45 PM
    tvbd56
    tvbd56 Epic Member
    Tyler
    Sacramento, Ca
    2018 Black DCLB OR 4x4
    depending on how many miles your air filter has been in there. You might as well replace it, you never want to give your engine dirty air.
  7. Mar 16, 2014 at 1:45 PM
    bra
    Badges off
    This is a cotton one right?
  8. Mar 16, 2014 at 1:49 PM
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    Off topic, but holy sh--!!! That ref is serious. :D My God, did someone shoot him out of a cannon?
  9. Mar 16, 2014 at 1:52 PM
    Graham
    Graham Pay it Forward
    Western New York
    2005 4x4 TRD Black V6 6 speed manual
    Haynes manual says 5W 30 for all temps or 10W 30 for areas that don't see below -18C. I have an oil free air filter that I clean every 6 months. A little more expensive up front but much cheaper over the life of the truck
  10. Mar 16, 2014 at 3:25 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    You could i guess if it has large debris in it. I just change mine every 25k. Sometimes i check it if ive been in a dusty environment. The filters are only about $15-20.
    Oil filters take time. Have to wash it, wait for it to dry, try not to over oil it. While the disposable is done in 5 mins
  11. Mar 16, 2014 at 4:13 PM
    bra
    Badges off
    Yes but does the TRD air filter is safe to use? Compared to the original one?
  12. Mar 16, 2014 at 4:19 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Yeah its safe to use. Just be careful to not over oil it. The oil can get on the MAF and cause poor running condition but thats about it. You should clean the MAF and throttle body once ayear anyways.
  13. Mar 16, 2014 at 5:05 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    This chart is what OEM uses.
