Engine Oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by barry694, Aug 20, 2015.
  1. Aug 20, 2015 at 6:31 PM
    barry694
    barry694 [OP] Member
    Barry
    2015 Tacoma Double Cab Prerunner
    None
    Every Toyota and Lexus I have, and have owned since 2010 called for synthetic oil. Recently sold 2011 4RUNNER that has same engine (4.0L) that is in the Tacoma. Stated use synthetic and change every 10,000 miles. My two Lexus vehicles are the same. Do you guys used the dino oil and change every 5,000 or do you go synthetic route for the Tacoma.
  2. Aug 20, 2015 at 7:45 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I use Mobil 1 and change every 5,000 Miles.
  3. Aug 20, 2015 at 7:47 PM
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    +1 for mobil one synthetic
  4. Aug 20, 2015 at 7:54 PM
    taco duck
    taco duck Well-Known Member
    SR5
    I do dino at 5k. its what the manual calls for. Out of warranty, I would prob run mobil 1 at 7500k intervals. I put 12k miles per year on my truck, and don't tow heavy, so I'm ok with dino.
  5. Aug 20, 2015 at 7:55 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    lol Okay as a novice I should point out it took me a moment to figure out what "dino oil" was. Conventional motor oil derived from crude oil that's been buried in the earth since the age of dinosaurs.
    Since Toyota is paying for my service for the first 25k miles I'm letting them do it with their conventional @ 5k.
    My 2005 Camry SE V6 called for conventional as well.
  6. Aug 20, 2015 at 7:59 PM
    Pigpen
    Dan
    Northwest Montana
    Mobil 1, but still change oil and filter at 5k. Then I run the oil in my chainsaws as bar oil. Sometimes I mix in gear oil, around every 30k I have a "fresh" supply of that. :)
  7. Aug 20, 2015 at 8:05 PM
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    havoline synthetic every 5k, and a mobil 1 filter
  8. Aug 20, 2015 at 8:10 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    +1
  9. Aug 20, 2015 at 9:03 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    thats my routine as well.... Mobile 1 0w-30 full syn
  10. Aug 20, 2015 at 9:11 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Mobile 1 7500mile interval with oem filter
