Engine Oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nakamura, Apr 10, 2019.
  1. Apr 10, 2019 at 5:19 AM
    Nakamura
    Nakamura [OP] Active Member
    Hilmer
    2005 Toyota Tacoma prerunner
    Leveling kit 3” front 2”rear and 20” wheels
    Im about to change my oil but I don’t know which one is the best one to use since I have 281227 miles. Please let me know what you recommend.
  2. Apr 10, 2019 at 5:21 AM
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    The same for the past 281,227 miles
    Rick's 2012, PzTank, eherlihy and 6 others like this.
  3. Apr 10, 2019 at 5:22 AM
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Millions of threads discussing oil on here, what have you been using? Assuming this is your first oil change since buying it (or having it done by others) you're probably safe to go with any conventional or high mileage 5w-30. Believe it's 5 quarts without changing filter, 5.5 with.
  4. Apr 10, 2019 at 6:20 AM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
  5. Apr 10, 2019 at 6:25 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
  6. Apr 10, 2019 at 6:25 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    The oil fill cap tells you what weight oil to use.
  7. Apr 10, 2019 at 6:27 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
  8. Apr 10, 2019 at 6:32 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
  9. Apr 11, 2019 at 4:15 AM
    Nakamura
    Hilmer
    There are so many suggestions that’s why I ask but thanks everyone.
  10. Apr 11, 2019 at 4:20 AM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    I tend to pass on high mileage oil unless there are already leaks. Which there almost certainly is at that mileage, but, fwiw.
