Engine overheating with AC on while off-roading
Discussion in '1st Gen. Tacomas (1995-2004)' started by eon_blue, Jun 3, 2016.
  1. Jun 6, 2016 at 10:53 PM
    #41
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    You'll notice a difference with a fan clutch vs the electric fans. And that noise from the ac, if its a hiss every once in a while I wouldn't worry about it. Both my Tacoma and my fathers do it. Mines done it since it was new
    eon_blue[OP] likes this.
  2. Jun 6, 2016 at 11:02 PM
    #42
    eon_blue
    eon_blue [OP] If I would, could you
    Azusa, CA
    It's a pretty loud hiss; it follows an equally loud "inhale" is the best way to describe it....it sounds like my air conditioning has a terrible case of emphysema.
    It works though, but I do remember one time I turned it on and the noise was louder than usual and all it blew out was warm air. I turned it off and back on, and it blew cold. I'm thinking the system needs some serious servicing.
    DustStorm4x4 likes this.
  3. Jun 7, 2016 at 6:15 AM
    #43
    Empty_Lord
    Dan
    it never hurts to check. another possibility is the fans not pulling enough air to effectively cool the Freon in the system
  4. Jun 7, 2016 at 11:24 AM
    #44
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    This thread echos like a cave.
  5. Jun 7, 2016 at 1:12 PM
    #45
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    Exactly.
  6. Jun 13, 2016 at 2:40 PM
    #46
    TACOconvert2012
    TACOconvert2012 My truck hates you. My wallet hates you.
    Socal
    SC'd 2012 MGM TX/Pro 4x4
    never ending..
    Just to chime in here for you as I had a heating issue as well, nothing severe, but this is what we found.
    I noticed you said you are supercharged well so am I. The intercooler blocks a significant amount of airflow to both your radiator and your AC condenser.. I would bet $$ that that flex-a-lite setup was not intended for supercharged/4x4 vehicles. On a regular 4x4 "might" be ok as your airflow is not obstructed, but a prerunner would probably be able to run it better than you.
    this lack of airflow is hurting both your AC and your engine cooling..
