Engine overheats, coolant level drops
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, May 17, 2015.
Thread Status:
Not open for further replies.
  1. May 17, 2015 at 1:27 PM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    This morning my check engine light came on. As I was 4 hrs away from home, I couldn't check the OBD status and had to get going. After maybe 30 min driving, the truck stopped on an uphill in the 2nd speed and wouldn't turn on again. Then I noticed steam coming out of the coolant tank and inside it looked like the coolant was boiling pretty hard.
    I rested the truck for about 45 min on the side of the road and refilled the coolant tank with water, as I didn't have any coolant. After I started the truck and went on the road, the engine overheated quickly after about 3/4 mi so I stopped again and got towed to a nearby town.
    Once in town on a mechanic shop parking lot (it's Sunday so they're closed), I tried to diagnose if there are any leaks in the coolant piping system by letting the engine idle and I found that some liquid was leaking from an open ended rubber nipple (is this supposed to be hooked into something?) that comes out of the firewall on the passengers side (picture attached). Also the fat aluminum pipe that also comes out of the firewall, has a capped nozzle, and goes into the bottom of the engine block gets really cold and the underside of it collects and drips some liquid (picture also attached).
    After that, we were able to drive it some 1/2 mi at 25 mph to a nearby motel without overheating but we're 180 mi away from home, where I would like to ideally get the truck to under some temporary fix so that I can work on the proper fix, if possible.
    Any idea where the leak could be and if I may be able to make a temporary fix with supplies from a local Walmart to which I believe I can safely drive?
    P.S.: I also noticed my serpentine belt was worn down to about half the width. Not likely to be causing a coolant leak but mentioning just in case.
  2. May 17, 2015 at 1:46 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    first picture is the drain tube for your AC, (just water that drips out). Second picture, that is an AC line (any silver aluminum lines are AC lines), it will get cold and sometimes frost up normal. Third picture major problem, your belt has come off of the power steering pump and the edges are frayed. something has worn out and gave, I recommend taking it to a shop and have it check out.
    *After looking again third picture, your belt on that pulley is half gone, shreded off.)
    Brie and foampile[OP] like this.
  3. May 17, 2015 at 1:51 PM
    foampile
    Mid-Atlantic
    It's not actually off, it's just worn down to about half the width. But it's still turning.
  4. May 17, 2015 at 1:57 PM
    foampile
    Mid-Atlantic
    the oil is at the second notch from the tip, looks alright brownish. I think that I may have not had the radiator cap on tight when I first drove off, which could explain. Also, when I took it off for the first time, it seemed like the gasket from the cap (white plastic ring) was loose and fell off into the pipe but I took it out with a screwdriver. Could that be causing it to steam off?
    When the truck is idling, the engine doesn't overheat.
  5. May 17, 2015 at 2:02 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    If the water pump isn't turning the engine will overheat very quickly. I had a fan belt break once going up a hill, I figured I'd fix it at the top. Temperature gauge was pegged in 15 seconds, it demanded attention now.
    I'd replace the belt first and see if that fixes it. Most blown head gaskets are the result of overheating.
    Brie likes this.
  6. May 17, 2015 at 2:03 PM
    Grenade187
    Grenade187 Well-Known Member
    Eric
    Vancouver, BC
    07 TRD Sport 4.0L V6 SR5 DCLB
    Camburg +3.5 Long Travel kit, Fox 2.5" Body 8" Coilovers with Remote Res, Radflo Air Bumps, Total Chaos coil bucket gussets, cam tab gussets and spindle gussets; All-Pro front bumper and IFS skid; All-Pro standard leaf pack; Ubolt flip; shackle flip; Timbren bumps; Radflo 2.5" body extended travel rear shocks, remote res with comp adjust; Magnaflow cat-back; Doug Thorley long tube headers, and off-road Y-pipe; URD TCAI
    x2. I would change the belt imediately, chances are it isn't driving the water pump as well as it should so your coolant isn't flowing fast enough to cool off the engine. Belts are cheap, overheating your engine will rapidly increase wear.
  7. May 17, 2015 at 2:07 PM
    Grenade187
    Eric
    Vancouver, BC
    The rad cap is designed to vent excess pressure. My guess is your coolant is moving too slow through the engine so it gets hot enough to boil, in which case your rad cap will vent the steam. Not necessarily a bad rad cap.
  8. May 17, 2015 at 2:29 PM
    foampile
    Mid-Atlantic
    Is the water pump pumping the coolant through the engine?
  9. May 17, 2015 at 2:30 PM
    Grenade187
    Eric
    Vancouver, BC
    yes. it circulates coolant through the engine and radiator. It takes the heat out of the engine and goes through the radiator to cool off. The water pump is the central pulley on the front of the engine, right above the crankshaft pulley.
    Brie likes this.
  10. May 17, 2015 at 3:26 PM
    Why J
    Why J I'm the master of my own domain.
    2012 DCSB V6 SR5 Prerunner
    OEM Roof Rack, 3" lift, 1.25" Spidertrax Wheel Spacer, Front skid plate
    That looks like the A/C refrigerant line and condensation dripping.
  11. May 17, 2015 at 4:00 PM
    foampile
    Mid-Atlantic
    I went to Advance Auto, got a new belt, mounted it on, works fine, no overheating so far after a few miles. There is, however, a small radiator leak on the lower right (passenger side) corner of the radiator. I saw it when I took the skid plate off to pull the tensioner.
    Thanks y'all for the feedback.
  12. May 17, 2015 at 4:05 PM
    723rdCAT
    723rdCAT Well-Known Member
    Kentucky
    15 SR5 4x4 access cab mgm
    If you ignored the half worn away belt in the third photo. Already established that those are refrigerant lines and thus not the issue.
  13. May 17, 2015 at 4:54 PM
    foampile
    Mid-Atlantic
    Unfortunately, it's overheating again after some 20 mi driving. The new serpentine belt works fine. It has to be something else.
  14. May 17, 2015 at 4:56 PM
    foampile
    Mid-Atlantic
    I refilled the coolant tank with 50/50 and maybe after 20 mi it overheated again.
  15. May 17, 2015 at 5:00 PM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    You can pressure test your cooling system, they sell kits to do it. Or have it done. It will help find the leaks too.
    Brie likes this.
  16. May 17, 2015 at 5:17 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    If the radiator is leaking, and you drive it on the highway, that trickle will turn into a big stream as it warms up and pressure rises. All the pressure inside caused by the water wanting to flash to steam instead turns to pressure that will empty the radiator. Doesn't have to be empty to cause a problem, just needs to air-lock the water pump. Also with a leak it is doubtful lost water will be replaced from the reservoir when it cools since air will leak in at the radiator leak rather than pulling water up and into the top.
    Some questions come to mind.
    Main one is what is the condition of the coolant? I had a friend once (ford taurus I think) that stopped by with overheating issues. Radiator fluid looked like coffee. flushed and filled with plain water to test, with thermostat removed, no water coming from the upper hose end. We took water pump off, and found that the vanes on the pump were completely gone. Normally they have an angle bent that is used to "sling" the water out. None on his. Replaced, refilled, and all was good. Ugly coolant is not just something bad to look at, it heralds other problems.
    I assume when you added water you refilled the radiator and not the reservoir? Believe it or not I know someone who shall remain nameless to protect the guilty, that had a major overheating episode. Told them to add water and we'd check the next day (this was late at night when nothing parts-wise was open). Called me back and said it was overheating again and they had no water. Drove about 15 miles with a 5 gallon can of water. When I took the rad cap off and poured water in he asked "what are you doing? Water goes in over HERE. (pointing to the reservoir)." I asked "how in the hell is it going to pull the water in from that, do you think there is a rat in the radiator with a LONG straw or something?" To make it short, once we got the trapped air out and antifreeze in, all worked well (his had a couple of bleeder points on a couple of high-point water hoses that could trap air.).
    Once you replace rad, which is not a hard job, you still have to take your time to get most of the trapped air out. Air will eventually dissolve in the anti-freeze solution, but not very quickly. Get a big bubble of air and it can air-lock the water pump and it will overheat quickly. The service manual gives hints, but the main problem is always the upper radiator hose. Air is less dense than water and always seeks the highest point. That is often a hump in the upper (return) radiator hose. Ideally you end up with nothing but liquid in there.
    Brie, RogueTRD and TacomaMike37 like this.
  17. May 17, 2015 at 5:32 PM
    foampile
    Mid-Atlantic
    I was putting water and later coolant in the tank that was open here in this picture. Should I have done it through the other cap to the left?
  18. May 17, 2015 at 5:40 PM
    Why J
    Check your oil and look for a milkshake on the dip stick.
    Does it overheat sitting at idle?
  19. May 17, 2015 at 5:42 PM
    Why J
    I am aware that the refrigerant lines are not the issue.
  20. May 17, 2015 at 5:44 PM
    foampile
    Mid-Atlantic
    Here is the dipstick
Thread Status:
