Engine Performance problem. Need help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Pauhana, Aug 7, 2017.
  1. Aug 9, 2017 at 4:51 PM
    eon_blue
    Azusa, CA
    The Torque app can pull codes via the scan tool and clear them, yes
  2. Aug 9, 2017 at 5:33 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    My scangauge II draws 100ma of current when the truck is off - not good for leaving it for awhile when out of town or camping. I assume these would too since the obd port supplies power?
  3. Aug 12, 2017 at 9:32 PM
    Pauhana
    Pauhana [OP] Well-Known Member
    Mark
    Irvine, CA
    04 SC PreRunner
    RECARO Trend Seats TRD SC URD Fuel Upgrades
    I figured out what the issue is. Even though I cleaned my MAF it was defective. I replaced it with a new one & the truck is running great. I did order the scanner but it's not in yet. Will try it out once it comes in on Monday.
    Dalandser likes this.
  4. Aug 17, 2017 at 9:00 AM
    preybird1
    preybird1 02 taco on 37's
    Russ
    Salt lake city Utah
    2002 taco s\c
    Trd S\C with nosecone hybrid bearing upgrade kit. 2.0 urd pulley, 7th injector kit-urd "6 fabtech lift with 3" body lift. 20" XD spy wheels with toyo open country r\t's in 37"x 12.50x20. Front and rear diffs re-geared to 4.88 dirty 30 drive axles. and a rhino pack clutch. Custom exhaust and huge mudflaps!
    That's great news you figured it out. My brother is a master mechanic of 25yrs and one time i saw him do a cold air intake for a customer. And you had to remove the MAF and install it into the new supplied intake tube but if you didn't pay attention to the orientation so the air flowed the right direction it would not run at all or horribly. It took him an hour to figure it out. Once he scanned the system it showed no air readings at all from the MAF he realized it was installed backwards and air only flows one way through that sensor. It was pretty damn funny!
