engine pinging?? 2015 DCSB w/ 40k miles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pca501212, Oct 7, 2019.
  1. Oct 22, 2019 at 4:55 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    My 15 doesn’t ping on 87 with 83K miles. I run a P.E.A type fuel system cleaner every oil change.
  2. Oct 22, 2019 at 5:52 PM
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    Mine pinged, then I got the TSB around 20k miles, and it still pinged although a little less. Then I started using premium and it almost never pings and seems to have better power on the low end (like it is able to use more timing without pinging). I just run premium all the time. Pretty crappy situation.
    OP might be due for spark plugs too. That helped mine.
    irayfz6[QUOTED] likes this.
  3. Oct 22, 2019 at 6:25 PM
    pca501212
    pca501212 [OP] Well-Known Member
    Alex
    Houston
    Thanks for the tip. And I did change out my spark plugs at 35k miles. I'm at 40k and it just started pinging about a couple weeks ago. Yikes
  4. Oct 22, 2019 at 6:45 PM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    I run 89/midgrade & its great for my truck. I use a gas app to locate the best prices
  5. Oct 22, 2019 at 7:03 PM
    TacoLyfe867
    TacoLyfe867 Well-Known Member
    Art
    2013 4x4 Tacoma TRD
    Got the same issue on my 13. Still pings with our shitty CA 91 octane gas. Thinking about doing the TSB but ive heard people had mixed results. Filling up with 91 is starting to get expensive, especially here in CA where we get fucked on gas prices for whatever reason.
    pca501212[OP] likes this.
