Engine Pinging & Disappointed with Toyota
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SAXD Taco, May 30, 2013.
  1. May 31, 2013 at 7:13 AM
    #41
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    the engine is not designed for 87 octane from everyone I have spoken to..... when the FJ had the same engine it said it had to run mid grade.
    My assumption is Toyota only downgraded the octane to keep the yearly fuel cost data down for the Tacoma which is a gas hog.
  2. May 31, 2013 at 7:14 AM
    #42
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    you might get away with 87octane when its under 50*F though. I find temperature plays a part too!
  3. May 31, 2013 at 7:30 AM
    #43
    BamaToy1997
    Bill
    Navarre, FL
    Pretty much the same thing, yes.
    Yes and no. Ethanol increases octane rating of gasoline when it is blended in. Because of this many gasoline refineries will use an even LOWER octane fuel before blending to save money. Basically instead of making 87 octane fuel, then blend say 10% ethanol with 85 octane fuel to get a final blend mix of 87. If this blending is not perfect, or if they try to cut corners, then the end result is fuel that is more susceptible to pre-ignition, or pinging.
    Not very sound advice or vehicle ownership method. Take care of your vehicle and it will last longer. Pinging can EASILY damage an engine permanently, and I like the idea personally of taking CARE of the car/truck that I have, not run it into the ground if a problem develops and then replace the engine, or expect warranty to do it. What ever happened to taking pride in one's car or truck?
  4. May 31, 2013 at 8:09 AM
    #44
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    This /\
    Pinging has less to do with truck, more with fuel + environment.
    When temperature rises, and you don't want to ride high rpms than only solution is to go to premium.
    In winter you can run 87 no problems but above 50 F you should be running premium.
  5. May 31, 2013 at 8:16 AM
    #45
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    pinging induces severe stress on wrist pin and connecting rod bearings
    these bearing parts are designed to work from a 'push' from the piston, not a hammer blow
    not as severe as a backfire (enough backfires can really loosen up bearings)
    but pinging is never good. knock sensors should be able to eliminate it
    but if pinging continues a remedy must be found. either downshift and rev
    higher (reduce engine load), or gas octane, plugs...whatever.
    constant pings = engine death eventually
    *backfires. I once did a series of tests with a new Yamaha 660 motor (think Raptor ATV)
    and induced 60 backfires by messing with fuel and ignition on a bench. after 250 hours,
    with 2 backfires in sequence per 8 hour cycle, the connecting rod bearing shat the bed
    this was to prove out a warranty issue with MZ Motorrad-und Zweiradwerk GmbH..they had
    a little defect on a line of Del'Orto carbs, and some backfires could not be prevented and people
    were getting engine damage
  6. May 31, 2013 at 8:37 AM
    #46
    BamaToy1997
    Bill
    Navarre, FL
    Yep, and it can also play hell on piston faces as well.
  7. May 31, 2013 at 8:37 AM
    #47
    disc0monkey
    don't forget about busting ring lands
    this isnt a good way to knock off carbon build up?? haha
  8. May 31, 2013 at 9:17 AM
    #48
    XXXX
    sKiP
    05 Prius
    Ill be running premium in my new engine. :)
  9. May 31, 2013 at 9:25 AM
    #49
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    :notsure: no ping for me, and all I have ever ran was 87.
  10. May 31, 2013 at 5:49 PM
    #50
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    I don't want to get into a pissing match with you, because your automotive knowledge is much more vast and respectable than mine, but you struck a nerve with that pride in ownership stuff;).
    my point was moreso not to run it into the ground, but to follow Toyota's advice. if they say its good to run 87, run it. im ASSUMING the op's truck doesn't sound like a marble in a tin-can constantly, so what is the fix? replace brand new knock sensors? the brand new wiring? the brand new ecm? I don't see how there could possibly be a problem with this.
    so, aside from those trying to convince the op to spend more money than necessary, im trying to give him some relief: if Toyota says its good as is, run it. unless he's one of those guys that's waiting for someone else to compliment him on the fuel grade he runs
  11. Jun 1, 2013 at 11:17 AM
    #51
    BamaToy1997
    Bill
    Navarre, FL
    I see how my comment could be perceived as a jab. I apologize for that. The point I was making was just because a manufacturer says you CAN do something, does not in itself mean you SHOULD do that. Some manufacturers say that transmission fluid NEVER needs servicing. Personally I would NEVER run a vehicle for it's lifetime without servicing the transmission.
    Now if he IS experiencing a large amount of pinging, then perhaps it would be a good idea to have a dealer look at it. It is not uncommon for a brand new vehicle to have problems. Over the years I have seen hundreds of cars/trucks with less than 1000 miles on them have failed sensors and computers. It is part of the "mass production" problems. Perhaps he has a knock sensor that is not responding well. Who knows?
  12. Jun 1, 2013 at 1:30 PM
    #52
    TrdSurgie
    TrdSurgie revised
    Oahu
    1gr engine was designed to run 91 octain. It can run on 87 because the motor can compensate. Toyota reduced the stated requirement to increase inventory movement(I assume). Alot of people wont buy a vehicle the requires high octain.
    Just spend the extra 4 bucks and do whats right for your truck.
  13. Jun 1, 2013 at 3:04 PM
    #53
    92dlxman
    Kevin
    Visalia, CA
    points taken, this thread might even make me a convert lol. . . ima at least try it
  14. Jun 1, 2013 at 6:39 PM
    #54
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    :cool:
  15. Jun 2, 2013 at 2:33 PM
    #55
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    I find it interesting though, that a couple owners have had this issue, & corrected it by installing iridium spark plugs. If thats all it takes, install them.
  16. Jun 2, 2013 at 5:02 PM
    #56
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    How about the tens of thousands of owners that have engines that don't ping?
  17. Jun 2, 2013 at 5:05 PM
    #57
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    If your engine is going to ping it is going to do it when you stall the torque converter at a stand still can you make it do it then?
  18. Jun 2, 2013 at 5:27 PM
    #58
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    in the metro phoenix area most of the gas comes from the same pipeline. The major difference is the detergents/additives each company puts in the fuel. 87 octane is 87 octane, by law. Mid grade is a Mixture of premium and regular.
    tanks can accumulate water in them but that just drops to the bottom.
    now when people say cheap gas I am not sure what they are talking about. Or old gas. Most retail places get gas at least once a week.
    with saying that I go Costco or sams club.
  19. Jun 3, 2013 at 3:47 AM
    #59
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    They don't whine.
  20. Jun 3, 2013 at 4:18 AM
    #60
    Buck717
    Buck717 Well-Known Member
    Middletown, P.A.
    2011 TRD off road DC
    BDS 6" lift 33x12.5 Mickey mtz 18" XD monster rims White knuckle rock sliders Boztec rear diff plate Rear diff vent mod Compustar alarm/remote start with two way remote.
    87 all the time, never pings.
    2011
    V6
    Auto trans
    Factory plugs
    13k miles
