Engine problem 1994 3.0 V6 small pick up.
Discussion in '1st Gen. Tacomas (1995-2004)' started by drumboy77, Jul 28, 2010.
  1. Jul 28, 2010 at 8:10 PM
    drumboy77
    drumboy77 [OP] New Member
    Peter
    Columbia, MD
    V6 tacoma
    Hi, my name is Peter, Jessup Maryland.
    I have 1994 Toyota Pick-Up, it has over 200,000 miles and now it needs headgasket. I don't know if I should go with another engine or just head gasket replacement. But if I go with the engine I'm planning to go with the used engine but as of right now, I don't know what to do... I need some advice.
  2. Jul 28, 2010 at 8:13 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    What do you want to know besides expensive. I have a 91' 3.0 and it is a lot of work to re do. If you are going to do it do it right because that engine is sensitive.
  3. Jul 29, 2010 at 5:34 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    I'd try to find a lower mileage replacement engine. There should be some out of '03's and '04's in wrecking yards with half the mileage you have on yours.
  4. Jul 29, 2010 at 6:08 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    The 3.0's always blow head gaskets, I would find a wrecked 3.4 and swap it out.
  5. Jul 29, 2010 at 7:28 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if i were you.....i'd do as others have said and find a good used 3.4 and swap it in.
  6. Jul 30, 2010 at 11:15 AM
    desertdude59
    If you go with the 3.4 then there will be some modification. I think you will need a body lift. Guess the engine sits higher than the 3.0. I saw a guys build plus there will be some wiring issues you will have to deal with. Also heard 3.4's have somehead gasket issues too.
  7. Jul 30, 2010 at 11:52 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Curious where you heard that. I have never heard of the 3.4L v6 having head gasket problems. In fact, compared with the 3.0L, the v6 in the Tacoma's is pretty much bulletproof.
  8. Jul 30, 2010 at 12:48 PM
    desertdude59
    http://www.yotatech.com/f2/3-4-head-gasket-recall-23329/
    This is the closest I could find, but I read it somewhere else too
  9. Jul 30, 2010 at 12:51 PM
    desertdude59
  10. Jul 30, 2010 at 12:53 PM
    98tacoma27
    Ben
    Not Beech Creek
    That was only for a couple years and is pretty much non-exsistent now.
  11. Jul 30, 2010 at 12:55 PM
    desertdude59
    Yeah. The 3.0 was the king of the head gaskets, but there was the small recall on the 3.4. Just something to be aware of for the OP.
  12. Jul 30, 2010 at 1:08 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    The 3.0 had a huge recall years ago to the point of Toyota doing complete engine R&R, my friend has an 88' 4 runner (pretty sure its an 1988) & even though he wasn't original owner Toyota did complete engine exchange with the recall at no expense to him, showing once again that Toyota did the right thing & it was due to a design flaw in cooling system,pretty sure it had something to do with small water jackets or lack of, Hey Chris 4x4 chime in here buddy I'm sure you know the skinny on this.... Anyway the 3.4 has proven itself to be a superior engine in reliability & performance. kinda like the difference between the 1985 Ford 2.8 v6 & the 1986 2.9 v6 where the 2.8 was a carburated POS & the 2.9 injected motor was much better performer & reliable.....:cool:
  13. Jul 30, 2010 at 11:14 PM
    desertdude59
    Yes that is true about the water jackets. When the 3.0 was introduced it was the first time they used a graphite head gasket. There was also the exhaust cross over pipe between the heads that didnt help either. Pretty sure that the 3.4 has the same exhaust set up. The fact that the block is steel with the use of aluminum heads is a possible issue too. There was just some design flaws along the way. The 3.4 also has a Multi-Layered head gasket offered too and the 3.0 doesnt. (believe me I've looked. lol)
    I do agree with the 3.4 being a better engine because of the head changes and the hard lesson learned from the 3.0. There was still that couple year head gasket recall that I was telling the OP about. Hopefully he wont pick up one of those engines.
  14. Jul 30, 2010 at 11:33 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    X2, yep theres still a few of those heat prone 3.0's out there & like you said hopefully he won't pick one of the earlier 3.0'
    Also I'm not sure what differences and/or mods he'd have to do with a 3.0 to 3.4 swap, probably worth checking into
  15. Jul 30, 2010 at 11:59 PM
    YeahYeah
    YeahYeah Well-Known Member
    Thomas
    (My Home - Murrieta, CA) Now, Alexandria, VA
    07 Tacoma Pre-Runner
    mud flaps gone, second air-filter gone, DTRL, fog light whenever and work with hi-beams, cut exhaust (was wicked flow), flat black stock rims, ABS switch, cup holder led's (with switch), turning signal mod #45, Bilstien 5100's, grill mesh
    http://lkqpowertrain.reachlocal.com/ try these guys out:) ull be satisfied. trust me.
  16. Jul 31, 2010 at 10:21 AM
    desertdude59
    I have the 3.0 in my '91. I've learned a lot about that engine over time. lol. I rebuilt it when I first got it. It ran like a champ. Then it got an intake leak that I was unaware of and it burned up a piston. I rebuilt it a second time and had a some guys do it. They did a terrible job. It ran like crap. The 3rd time I did all the work my self. Took my heads to a shop where I know the owner. He did all the work on the heads. I put the engine back together. Now its turn key. Pulled a 1,000 lbs of junk on a trailer plus the trailer the other day and it ran like a champ. I personally wouldnt trust a junk yard 3.0 without a rebuild so if I were the OP just go through the engine he has now and save a buck.
  17. Jul 31, 2010 at 10:28 AM
    Taco GTR
    Taco GTR Valdosta State University
    Orrin
    Shadydale/ Valdosta
    2003 Tacoma reg cab.
    Bone ass stock, 2nd air filter delete, JVC head unit, Alpine 600watt amp, JVC 1600 watt 12'' sub, Tractor Supply Company Toolbox, ALOT MORE TO COME.
    ok so im about to buy a used 96 tacoma reg cab with the 3.4. should i look out for the head gasket cause its an early model??
  18. Jul 31, 2010 at 10:31 AM
    desertdude59
    I would get the vin and call toyota. One of those links I posted said something about '96 & '97 having a recall.
