engine problems
Discussion in 'Performance and Tuning' started by TacomaJohn, Dec 20, 2009.
  1. Dec 20, 2009 at 9:20 PM
    TacomaJohn
    TacomaJohn [OP] Member
    2007 DC 4x4 V6
    Debadged, fog light mod tacoma mats
    so if i remove my cats and run a 2.25 inch exhaust what kinds of negative side effects wil that cause on my engine?
  2. Dec 20, 2009 at 9:27 PM
    TacomaJohn
    2007 DC 4x4 V6
    no way..thats amazing..but other than this there is no other programer? like on my F250 i could run several programmers for the diesel and the turbo
  3. Dec 20, 2009 at 9:30 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    the reduction in backpressure may have some negative side effects i would do some more investigation before i did this. you may decrease horsepower
  4. Dec 20, 2009 at 9:31 PM
    TacomaJohn
    2007 DC 4x4 V6
    oh ok..great
  5. Dec 21, 2009 at 4:31 AM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    The truck has two sets of cats, so depending on which cats you eliminate you'll do 1 of 2 things.
    1. if you remove the front cats, you'll throw an o2 code.
    2. if you remove the rear cats, nothing will happen.
    Either or will increase the sound, and peak HP. You MIGHT lose a little low end, but IMO not enough to make any kind of real difference. You're just moving the torque higher up in the rpm range.
  6. Jan 1, 2010 at 1:55 PM
    GodHatesUsAll
    GodHatesUsAll Reign in Blood
    Satan
    Six Feet Under
    05' Black Sand Pearl XRunner
    TRD Blower//APR X-1//668cc Primaries & 7th inj//URD 2.8"&NST OD Pulleys//AFE StageII Si CAI//URD Fuel Pump//JBA GenII lT's//URD S/S//URD Lite Flywheel//Competition Clutch StageIII//NST Lite Pulleys//Sittin Sic Front coils/Rear Mono leafs//
